Losing Power after using Baja Design wire harness with BD ditch lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaMods#776, Nov 28, 2020.
  1. Nov 28, 2020 at 6:47 PM
    TacomaMods#776
    TacomaMods#776 [OP] New Member
    Danny
    2017 Tacoma magnetic gray 4x2
    Raptor lights, HDX side steps, Bed cover, Bfgoodrich tires 265/70/R17, Method Wheels, Squadron SAE fog lights, LED headlights, LED reverse lights, LED license plate light, Clazzio leather seats, TRD shift knob, Ditch lights with OEM switch
    Hello Tacoma Community! I'm new to the site and was hoping to get some help or advice.
    I recently got Baja Design Squadron ditch lights and ordered brackets, a Dual Leg Wire harness with a relay, and an OEM switch. I used the wire harness that Baja design provided but it didn't have the relay. After finishing installing I noticed the sign showed up Break Override malfunction but that went away after turning on and turning off the car. Then I noticed a loss of power after driving. SO should I use the Cali raised harness with relay instead? did I blow a fuse? I'm not sure so hoping to get help. I apologize for the long paragraph.
  2. Nov 28, 2020 at 6:50 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Are you running a relay on your current wiring harness?
  3. Nov 28, 2020 at 6:53 PM
    TacomaMods#776
    Danny
    No, could that be the problem?
  4. Nov 28, 2020 at 6:55 PM
    brandon78lusch
    Brandon
    Yeah that most likely is the problem. Other users received Brake Override Malfunction Errors when installing aftermarket lights, pedal commanders, etc.
    GusmanJE likes this.
  5. Nov 28, 2020 at 6:57 PM
    TacomaMods#776
    Danny
    I will try to replace it with the Cali Raised harness with relay instead then, hopefully, that does the trick. Thanks for your response!
