Losing power mystery
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacorunner10, Jul 14, 2019.
  1. Jul 14, 2019 at 12:57 PM
    Tacorunner10
    Tacorunner10 [OP] New Member
    I have a 98 Tacoma 2.7 5 speed. Here lately it has been acting up with acceleration. When accelerating, it's jumpy and not smooth with power. Boggs down when pressing peddle down further. It really starts spitting more around the 2 rpm range. Truck is drivable, idles and starts correctly. I changed spark plugs, wires, coil packs, and changed my fuel filter. Air filter is clean. I'm assuming I could have injector going out. I've used several fuel system cleaners with no luck. I wouldn't think this would be a mass air intake sensor, because truck still idles fine... Could try cleaning throttle body... Any suggestions? Thanks
  2. Jul 14, 2019 at 5:57 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Check the grounds in the engine bay.
  3. Jul 14, 2019 at 7:23 PM
    Matermax
    Matermax Well-Known Member
    Nathan
    NE Arizona
    1999 Tacoma TRD
    White Line LCA bushings.
    Is it throwing a code? I had similar performance from a bad injector and one time from a bad MAF sensor.
  4. Jul 14, 2019 at 7:29 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    When was the timing chain/belt done?
    A worn key way on the crank can make the timing bounce back and forth causing sputtering, power fall off, poor acceleration....etc
    So can a stretched chain or worn belt...
  5. Jul 14, 2019 at 7:54 PM
    Tacorunner10
    I’m going to see if it’s throwing a code tomorrow. Right now, I just did preventative maintenance, and to see if that would work first, cuz it needed a tune up. Engine has 170,000 miles, would timing chain be an issue around that mileage? 98 has a chain not belt right?
  6. Jul 14, 2019 at 9:46 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    If it idles fine, I don't see the timing chain as the primary cause.
    My first thought was coil or wires. But you changed that.
    This Toyota mechanic "Timmy The Toolman"
    has a lot of great Toyota Truck videos.
    Try his library.
    https://www.youtube.com/user/mtbtim65
  7. Jul 14, 2019 at 9:56 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Partially clogged catalytic converter?
    Would have drivability issues when accelerating and cruising.
    tcjacado and cruisedon66 like this.
  8. Jul 14, 2019 at 10:01 PM
    eon_blue
    Azusa, CA
    Just out of curiosity, would a bad or disconnected ground have an effect on overall performance like this? I discovered awhile back that my firewall ground (back of the block to the firewall) was badly burnt up, I replaced it with some thick gauge wire but I don't know how long it was like that for. Didn't notice any weird issues with the truck or anything. There are 3 (?) grounds in the engine bay right? Battery, back of the block, and one near the starter I think?
    CS_AR and Running Board Man like this.
  9. Jul 15, 2019 at 12:05 AM
    Glamisman
    Glamisman Well-Known Member
    my internet guess is the TPS... throttle position sensor.
  10. Jul 15, 2019 at 1:44 PM
    Tacorunner10
    Thanks everyone for the help! I still haven’t narrowed it down. Truck is throwing a code PO171. Maybe has a leak somewhere. Sprayed starting fluid around vacuum hoses, never stirred the idling. I think the grounds are good.. maybe just bad throttle body insides? I unplugged MAF sensor, truck shuts off. Still think it may could be the TPS sensor... where should I throw my money next?
  11. Jul 15, 2019 at 1:46 PM
    eon_blue
    Azusa, CA
    Try cleaning the MAF sensor with MAF cleaner (don't use generic electronics cleaner). My money is almost always on a small vacuum leak with P0171 codes unless they're in combination with other codes. But cleaning the MAF is an easy way to rule out a dirty one, unless it's just bad and needs to be replaced (in which case go with a Denso one, not something aftermarket). These trucks won't run without the MAF plugged in.
    Good luck...P0171 code is a bitch.
  12. Jul 15, 2019 at 1:50 PM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Mine was doing something like that back when my fuel pump was taking a dump. Mechanic said it wasn't able to keep up with fuel demand.
  13. Jul 15, 2019 at 2:40 PM
    Glamisman
    at this point in time my recommendation is to take her to a shop that has worked on Tacomas before... tell us where you live and maybe someone can point you to a good shop that they know of. Throwing parts at it hoping that it gets fixed just makes you poorer and upset.
