Losing Tire Pressure Overnight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by toyeti_taco, Jan 6, 2021.
  1. Jan 6, 2021 at 7:56 AM
    toyeti_taco
    toyeti_taco [OP] Member
    San Diego
    Cement DCLB
    I replaced my stock wheels and tires for a set of Methods nv's and BFGK02 a couple of weeks ago.
    Everything was fine until a trip to the snow last weekend. I dropped the tires to 15psi to increase traction and after about 5 hours of "wheeling" I proceeded to air up to 38psi. On the ride home the tires were holding air no problem. The next morning, I noticed the tire a little low, checked the pressure and it was at 28psi. I aired up, did my thing all day and parked the car for the night. Next morning, the tire was again at 28psi.
    I inspected the tire for visible damage and could not find anything. Took the truck to the shop where the tires were installed and they mentioned that the leak was coming from the TPMS sensor. They cleaned it, tightened and told me to keep an eye on it.
    Unfortunately, the tire keeps losing pressure, so here I am checking to see if any of you have had a similar problem and how you dealt with it.
    Thank you in advance!!
  2. Jan 6, 2021 at 7:58 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    spray your tire down with soapy water, if the leak is still coming from the tpms you might be better off just getting new ones.
  3. Jan 6, 2021 at 8:06 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    And make sure there is no damage or casting problems on the wheel where they mate.
    kahanabob likes this.
  4. Jan 6, 2021 at 9:37 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have had aftermarket wheels have slow leaks. I found them by soaking them is a pool of water and watched a slow bubble come from the wheel behind the spoke. It was a slow leak about one bubble every 45 seconds, little dab of jb weld, scratched the surface and made a quick patch. Never a problem since then. You also may had some dirt in the bead since you aired down a lot.
