Loss of FM Radio Preset Memory
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Volcanodude, Sep 24, 2012.
  1. Sep 24, 2012 at 10:47 AM
    Volcanodude
    Volcanodude [OP] New Member
    4cylinder SR5
    Several times now, I have had to reprogram my FM radio present buttons. While driving, press a selection button and an error message appears indicating: "Check Antenna". Initially I checked the antenna and re-tightened it but it did not work. I used the scan button in the FM mode and were able to obtain the different radio stations.
    This has happened about 6 times since bought the Taco in August. Any ideas on how to prevent this problem?
  2. Sep 24, 2012 at 10:49 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    My vote is on a loose wire somewhere. I would even go as far as checking the connections on the battery terminals, since disconecting the battery does erase the radio presets.
  3. Sep 24, 2012 at 10:49 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    It usually dumps presets when you unhook the battery... Otherwise the stock radios suck in our trucks I'd go with an aftermarket stereo
  4. Sep 24, 2012 at 12:15 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    This is OT but I like my stock radio. Probably the best stock unit I've ever owned. Sounds so nice that I used it's sound character as a model for my home stereo. It does not have teeth rattling bass or ear piercing highs but I really don't want those colorations any way. It has a very balanced sound without a hint of harshness. Whoever designed it did a great job.
  5. Sep 24, 2012 at 12:21 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    JBL or non JBL? mine was straight up the worse sounding stock stereo ive heard/
  6. Sep 24, 2012 at 3:54 PM
    BTO
    California
    I guess it's a non JBL but I believe there are different versions of the standard one. Mine sounds great but I do have it tweaked for optimal sound.
  7. Sep 24, 2012 at 7:15 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    If it's a 2012, why not get it fixed under the warranty?
  8. Sep 25, 2012 at 7:06 AM
    Volcanodude
    4cylinder SR5
    Thanks for the suggestion. I contacted my sales rep and this is his response below. Apparently when you are not in a satellite radio area, the scan button creates total confusion for the radio system.
    Thanks to all for your suggestions.
    The "check antenna" will appear when you scroll through the radio button. It will go through am,fm,and xm. Xm radio is a satellite radio however we do not receive satilite radio frequencies in Hawaii. Your truck is set up for it though. You can go into the settings and then into the presets and select fewer pages ie 3. It is at 6 pages from the factory.
  9. Sep 25, 2012 at 7:19 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    wut? That only makes sense if you are scanning through some preset XM stations. If you are on FM mode, it shouldn't try scanning through XM. But yes, "check antenna" will show under XM if it can't get a signal. None of this should cause it to lose your FM presets.
