Loss of oil pressure on steep decline 2011 V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Schoolhouse, Apr 27, 2025.
  1. Apr 27, 2025 at 10:01 PM
    Schoolhouse
    Schoolhouse [OP] New Member
    Reed
    2011 tacoma
    lifted in front
    I was going down a steep logging road and had to back up a few times to line up and squeeze between a log cut out of the road barely wide enough for the truck. the oil pressure light went on and the engine started clattering and there was a small puff of smoke from under the hood and a faint smell of fuel. I immediately shut the engine off and coasted down to a flat spot and checked the oil. It was full I crossed my fingers and started it back up. It clattered a little and the oil pressure light went off but the CEL remained on. It sounded normal. I drove home and check the codes.I got P021 and P0111 timing codes. I cleared two of them and the other two went away the next day along the the CEL. The big question is did I damage my engine? I have seen that inclines can cause issues like this on many newer tacomas but no one ever discuses solutions or causes other than design flaws.
  2. Apr 27, 2025 at 10:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did you hurt anything? Probably not.
    If you did, you'd know it by now.
    But don't do that again.
    You sent oil "away" from the pick up tube on the incline.
    And likely sent oil through the PCV into the intake (puff of smoke).
    Again, don't ever do that again.
    Carry on. Lesson learned.
  3. Apr 28, 2025 at 3:47 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    What degree of an incline?
    JAGCanada likes this.
  4. Apr 28, 2025 at 4:18 AM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Seems weird a road would be that steep to cause a problem.
