Loss of oil pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by desk, Nov 10, 2020.
  1. Nov 10, 2020 at 5:24 PM
    desk
    desk [OP] New Member
    Edward
    2012 2.7 4x4 base. mt
    went to work one day 80 mile round trip
    came home sat overnight
    went to move truck next day no oil pressure
    sending unit works
    nothing at all come out with sending out
  2. Nov 10, 2020 at 6:48 PM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    Dipstick? Puddle?
  3. Nov 10, 2020 at 7:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are you saying that you ran the engine with the sending unit removed and oil didn't squirt out of the hole for the sending unit?
    If so... Don't do that unless you want to replace the engine.
    Check the dipstick.
    Does it have oil?
    At the proper level?
  4. Nov 10, 2020 at 7:39 PM
    WOODY2
    RAMONA,CA.
    What assures you the sending unit works properly if no pressure is indicated? Think the dipstick would be where one would start and look for any oil discharge/streaking.
  5. Nov 10, 2020 at 8:09 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Need more info.
    Blockhead likes this.
  6. Nov 10, 2020 at 8:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Oil flows from the pan to the oil pump.
    From the oil pump to the oil filter.
    From the oil filter to the oil cooler (if equipped)
    Check your oil, then filter first.
    That’s the easiest things to check.
    Jimmyh likes this.
  7. Nov 11, 2020 at 1:12 AM
    desk
    Edward
    did all that
    changed filter / pressure relief inside
    pressure relief on pump ok
    front of engine off / pump ok
    pan off so far pick up ok
    just ran for a second to see if anything would come out
    wtf !
    have had trucks since 79
    79 2wd
    83 4x4
    82 2 wd
    77 2 wd
    92 4x4
    87 4x4
    rebuilt the engines taken whole trucks apart down to frame
    62 yrs old getting tired fast
    lynyrd3 likes this.
  8. Nov 11, 2020 at 1:19 AM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    How can you tell that you have no oil pressure? My 2015 base model only has an idiot light.
  9. Nov 11, 2020 at 2:47 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Wow this escalated fast...
    So When you ran it for a second to see if anything squirted out... Did it?
    I assume it did not since you have now torn it down to the intake screen and have the entire front of the engine off ( assuming timing cover etc...).
    How do you know that the pump is OK?
    Alexely999 likes this.
  10. Nov 11, 2020 at 3:47 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Welcome to TW!
  11. Nov 11, 2020 at 8:19 AM
    WOODY2
    RAMONA,CA.
    No chit! Problem anounced, no basic diagnostic info given, disappear, whats new? :bananadance:
  12. Nov 11, 2020 at 10:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  13. Nov 11, 2020 at 10:51 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    wait wat
