loss of power after head gasket replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by CaptTommyD, May 26, 2016.
  1. May 26, 2016 at 5:15 PM
    CaptTommyD
    CaptTommyD [OP] New Member
    Tommy
    1997 Taco
    Trucks a 97 taco 2.7l (3rz) had 204k when gasket let loose pulled head replaced gasket put back togeather and she runs idles smooth but I noticed the idle sits a little over 1k and also feels like it doesn't have as much power as it used to (and yes I know it's a 4 cyl) doesnt run hot and has no misses just a little loss of power any ideas guys?
  2. May 28, 2016 at 7:48 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Check ignition timing and vac leaks, thats where i would start, id pull the valve cover put it to tdc and double check the timing marks are lined up correctly
    Bxnanaz likes this.
