Loss of power...engine stalls....help me
Discussion in '1st Gen. Tacomas (1995-2004)' started by eganx, Aug 27, 2010.
  1. Aug 27, 2010 at 5:07 PM
    eganx
    eganx [OP] Well-Known Member
    Kingston WA
    99 Tacoma
    So I have a 99 tacoma, with a 3.4. I noticed it was running rough upon start up, lacked power, would buck if I tried to drive it. But after it warmed up was fine. This has grown into a major loss of power to where I am crawling up hills. If the engine is warm, I can floor it, the engine will bog and then accelerate, and as it revs the actual power will fluctuate greatly. As the RPMs increase the exaust pops/sputter and backfires. The truck is barley drivable.
    So.... no codes are thrown, spark plugs and wires are good, 02 sensor tested good, I cleaned the MAF sensor. I don't get it...if there were a misfire there would be a code, if a sensor was bad there would be a code....WTF? I am about to test the voltage from the TPS. I have yet to put a fuel pressure gauge on it, which will be my next step.
    Any advise???? I need to have my truck back up and running as it is my DD, and I can't take it to a shop since I make shit for money. HELP
  2. Aug 27, 2010 at 5:25 PM
    TacoMo510
    TacoMo510 newb
    Bay Area
    98 2.4 5spd
    k&n drop-in air filter, deckplate mod
    i had a problem where the engine would start up but die right away and only if i gave it a little gas for a minute or two would it keep going. and even then the rpm's would be too low. cleaned the throttle body with a little carb n choke cleaner and my problem faded away. i also didn't get any codes.
    start with giving the throttle body a good cleaning and then go from there. some people are picky with the cleaner that they use, they say that you're only supposed to use throttle body cleaner. but the carb n choke cleaner worked fine for me, just make sure to take the throttle body all the way off and make sure it dries off before installing.
    hope this helps.
  3. Aug 27, 2010 at 5:26 PM
    TacoMo510
    TacoMo510 newb
    Bay Area
    98 2.4 5spd
    also, if you do clean the throttle body, make sure to get the gasket before hand, just in case you mess up the one that's on there.
    heck, go ahead and just buy a new one, they're only like $2.
  4. Aug 27, 2010 at 5:41 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    And maybe try seafoam.:)
  5. Aug 27, 2010 at 6:08 PM
    Barnone
    Barnone Guest
    Plugged cat? Might take it off to see it that's the problem.
  6. Aug 27, 2010 at 6:09 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Its your Fuel pump bro, guarantee it.
    Edit: So listen man, i have a fuel pump that came out of my 95, it was in good working order when i removed it. It was replaced with a high flow for the super charger. Anyway if you need it, its yours, you just pay shipping.
    Cheers,
  7. Aug 27, 2010 at 9:46 PM
    eganx
    Kingston WA
    99 Tacoma
    the throttle body is clean...cleaned it out about 6 months ago. Thought about the plugged cat....the one under my truck is welded in. I am thinking about cutting it out.... if I cut it out to see if its clogged its not going back in either way.
    I'm leaning toward the fuel pump. There isn't anywhere I can borrow/rent a fuel pressure gauge......so I'm going to have to probably get a cheap on online.....
  8. Aug 27, 2010 at 9:50 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Sounds like an Air Flow Meter, to me. Try cleaning yours, before you rip the cat out.
  9. Aug 27, 2010 at 9:51 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    As mentioned before, I'd first check the fuel pressure and the throttle body.
    Check the airfilter for rodent/insect damage. They will go in there and shred your filter, the little bits will clog/confuse your airflow sensor and cause the power to fluctuate and vanish.
    It sounds like you have spark, check the fuel and air.
  10. Aug 27, 2010 at 10:06 PM
    eganx
    Kingston WA
    99 Tacoma
    as I stated in my OP " I cleaned the MAF sensor"
    I had to take my air filter out to clean the MAF and it was fine. I'm trying to find a fuel pressure gauge to borrow........until I can test the fuel pressure I can't really proceed much further
  11. Aug 28, 2010 at 3:21 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    You didn't mention changing your fuel filter, which would be a quick fix on the 3.4L. If its never been done before, I'd suspect its probably about time anyway. If your fuel pressure tests low, you'll end up replacing it anyway just to be certain thats not the cause.
    For a fuel pressure tester, I'd just go pick up a cheap one at Harbor Freight. Its not the best, but if you use teflon tape on the threads, it should be able to give you a go/no go for pressure values easy enough. For a one time use item, the price and quality really isn't that bad.
    Also, have you checked your local auto part stores to see if they rent one? Probably not due to different fuels and such, but its worth a shot.
  12. Aug 28, 2010 at 8:08 AM
    eganx
    Kingston WA
    99 Tacoma
    fuel filter was replaced 6 months ago. I thought about harbor freight but the closest one is a hour and a half away. None of the autoparts stores rent/loan one, and the cheapest one in an autoparts store I could find was $50....which I don't have to spend on that at the moment
  13. Aug 28, 2010 at 1:38 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    Well, its not as exact, but since a fuel pump is also measured in gals/hour (liters/hour), you could also measure the amount of fuel that comes out of the feed line for a small duration. I couldn't easily find what our stock pumps are rated at though.
  14. Aug 28, 2010 at 7:00 PM
    eganx
    Kingston WA
    99 Tacoma
    good point.....but I sold a car today(a car I bought to flip)so I will have a little extra cash.....fuel pressure test gauge here I come.
  15. Aug 28, 2010 at 8:40 PM
    eganx
    Kingston WA
    99 Tacoma
    so what about the three coils........I have yet to test these. Anyone have any experience with these going bad? Anyone know the resistance specs on these????
  16. Aug 28, 2010 at 11:19 PM
    swsteven
    swsteven Well-Known Member
    houston tx
    2001 tacoma trd
    3 inch lift bilsteins and aal 16 inch pro comp wheels, m/t tires
    fuel pump or bad gas
  17. Aug 28, 2010 at 11:58 PM
    eganx
    Kingston WA
    99 Tacoma
    thanks for the diagnosis big chief
    Update - checked resistance of all three coils....all are good
    could some carbon have made its way into the idle air valve on the bottom of the throttle body???
    I am also thinking the MAF could be bad.....I'm going to hook up my computer and watch the fuel trim....
  18. Aug 31, 2010 at 10:11 PM
    eganx
    Kingston WA
    99 Tacoma
    The long term fuel trim was -13%....which mean the computer was deducting 13% of the fuel from the map, AKA the truck is running rich. So I now have to check fuel pressure to see if its a bad fuel pressure regulator, bad vacuum line to the FPR, pinched fuel return line etc......and if the fuel pressure is fine then my bet is the MAF is giving a false reading telling the ECU the engine is breathing more air than it really is....
  19. May 3, 2013 at 1:41 PM
    NW4RUNNER
    NW4RUNNER Well-Known Member
    4 runner trail
    Any diagnosis for this? My 3.4 is sporadically stalling under load after shifting. I'm s/c with 7th inj, new plugs and fuel pump. Feels like throttle related since truck doesn't seem to be pinging. Any ideas? Also no CEL.
  20. May 3, 2013 at 7:18 PM
    BamaToy1997
    Bill
    Navarre, FL
    You are correct that -13% is resulting is a reduction in fuel provided by the injectors. HOWEVER that fuel trim number is only an indication of several problems. Yes, you could have a MAF sensor that is bad, but you could also have a bad AF sensor that is incorrectly reading the O2 levels. You could have an injector that is leaking and causing a rich condition...etc. I know that you said you have limited funds, but replacing this part and that part gets really expensive fast. Sometimes it is best to take it in to a professional, and be honest with him. Tell him you need a diagnosis and that you will pay him for his time (Usually between $25 and $75) and find out what IS wrong, and then replace/repair a single problem, yourself, one time.
