Loss of power in sand
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mmcfaddenjr, Apr 4, 2022.
  1. Apr 12, 2023 at 3:23 AM
    sanuthomas
    sanuthomas Member
    sanu
    Toyota FJ cruiser
    Update.. I’ve changed the fuel pressure regulator at the common rail and the truck was back in action.. but after a few kilometers it goes back into the same old slow response. I had an error code for the knock sensors earlier, so I’m gonna change it tomorrow and see what happens ..
  2. Apr 12, 2023 at 1:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How many kilometers on your FJ? It sounds like a fuel pumping issue. When the vehicle is on an incline.
  3. Apr 13, 2023 at 5:14 AM
    sanuthomas
    sanuthomas Member
    sanu
    Toyota FJ cruiser
    the car has done 237k and yeah the powerless starts when the car is on the incline...
  4. Apr 13, 2023 at 9:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    With a full tank of fuel or only when less than a quarter tank?
  5. Apr 13, 2023 at 10:11 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    If you do a lot of driving in the sand, maybe check your air filter? could be clogged and causing you to bog down when opening up the throttle
