Loss of power
Discussion in 'Performance and Tuning' started by slimilz, Mar 19, 2017.
  1. Mar 19, 2017 at 7:14 AM
    slimilz
    slimilz [OP] New Member
    2015 toyota tacoma
    Hello, I have a 2015 Tacoma, V6 , 6 speed manual transmission. I love this truck, recently though I am experiencing a loss of power when accelerating. This accrues in all 6 gears. For example... I will be driving down the road at average speed, average rpm's, step into the throttle a bit, the rpm tack will go up to lets say 3000+ rpm and my speed will not increase accordingly. Then my rpm will come down to where they should be and my speed will reach where it should be, but not without me decelerating a bit on the pedal. I have 42000 miles on my truck and have kept up with all maintenance along the way. I do not dog my truck, but at the same time I do not drive Ms. Daisy either. If anyone has any input on my situation, I would be greatly appreciated.
  2. Mar 19, 2017 at 7:17 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  3. Mar 19, 2017 at 9:12 AM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Yep, you have burned your clutch.
  4. Mar 19, 2017 at 9:13 AM
    Michal006
    Michal006 Well-Known Member
    PA
    2016 Tacoma TRD Sport 4x4 6MT
    Your clutch is slipping my friend
  5. Mar 20, 2017 at 12:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Aftermarket upgrade. Excedy, ACT, Spec Clutch, Centerforce....
