Loss of power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stillfly199, Sep 6, 2009.
  1. Sep 6, 2009 at 9:10 PM
    Stillfly199
    Stillfly199 [OP] ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    So we went and did a little wheelin today, nothing too crazy, just mainly logging roads with some fire line thats been water barred. No pics, noone had a camera. So I tried to go up one side of the fire line and it was pretty steep, and I get about 90% up it and it gets loose and I cant go any further. So I tried it probably 10 times and couldnt get passed the same spot. I had it in 4 low and in L, 2, 3, 4 and in 4 High L, 2, 3, 4 on an automatic transmission and when I would have my foot all the way into it, the rpm wouldnt go above 2k. Is this normal? Its a 2007 DC Sport, 4x4, 3" spacer lift, 285/70/17 BFG All Terrains, stock gearing. It was pretty steep, I dont want to admit this but a jeep made it up before me, but it took him a lot of tries so he had the trail pretty tore up before me. Any ideas? Does it do this on purose to try to lessen the chance of blowing the motor?
  2. Sep 6, 2009 at 9:15 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Good question. I want to know now.:popcorn:
  3. Sep 6, 2009 at 9:16 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Well i tried to get up to our hunting cabin in 4WH. It is in west virginia at the top of a mountain and the soil is very shale-y. There is one very steep part about 40 feet of road. I got about half way up and it bogged down and almost stalled if I didn't stomp the clutch and grab the ebrake.
    It seemed to be normal, just the engine can't put out enough power to keep the tires spinning
  4. Sep 6, 2009 at 9:19 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I figured it was something like that. It was really steep, by far the steepest i've tried. I was so pissed when the jeep made it up, but I did pull him out of a creek a coupld months back, so it wasnt all that bad.
  5. Sep 6, 2009 at 9:23 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Hey Jeeps and Toyotas working side by side? Its allllll goood!!!:D
  6. Sep 6, 2009 at 11:00 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I just remembered this too, While we were going over a waterbar, we were going slow so I didnt jack anything up, and the driver rear was stuffed all the way into the fender. When I would give it gas it wouldnt spin, but all the others would, well more so hop. Both rears dont spin in 4wd, correct? Its actually 3wd isnt it?
  7. Sep 6, 2009 at 11:07 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Depends on your setup. If you have a rear locker both will run at the same speed, one up front will go on open diff. If you have the LSD, you'll have some slip on the rear but can sorta lock at times with tricking it.
    So, basically most of the time, minus locker, you have one wheel front and back that has full power, and it'll be the one with the least resistance. Unless you're modified with front/rear lockers.
  8. Sep 7, 2009 at 7:27 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    K thats what I thought I read somewhere. I do have the LSD. I have never had the truck at these angles before so it made me curious. Thanks for all the input.
  9. Sep 7, 2009 at 7:39 PM
    bt08231
    bt08231 Well-Known Member
    Baltimore, MD
    09 Magnetic Grey SR5
    Stock
    well i know when i spin my tires on wet pavement the engine cuts power to prevent the slippage, im pretty sure its some sort of traction control, mines an 09 though not sure if that matters.
  10. Sep 7, 2009 at 7:53 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    yeah I would say traction control of some sort, just a guess
  11. Sep 7, 2009 at 7:54 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Hit the little button that turns off Traction Control.
    Floor the fucker.
  12. Sep 7, 2009 at 7:56 PM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    yah, i think it being an 09 does matter. i thought that was a new feature for 09 and 10?
  13. Sep 7, 2009 at 8:55 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    When I looked in the rear view mirror the tire was stuffed into the fender and when I gave it gas I was figuring the tire was caught up or something.
  14. Sep 7, 2009 at 10:27 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Traction control uses the brakes. Turn it off. Glad I don't have that mumbo jumbo hi-tec stuff in mine!
  15. Sep 7, 2009 at 10:55 PM
    Illuminaut
    Illuminaut life's a conspiracy
    (Z)ion)o)sphere
    2009 Regular Cab 4x4 in BSP
    .75" Front Aluminum Billet Spacers = 1.5" Lift ((silly mud flaps removed pending trimming)) AFE Pro Dry S with secondary filter removed 265/70/16 Goodyear Wrangler Silent Armors mounted on Limited Edition Toyota Black Bajas
    That's what it is, alright... (pg 176 & pg 185 of "2009 Owner's Manual")
