Loss off performance?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tucker771, Jun 18, 2015.
  1. Jun 18, 2015 at 12:38 PM
    Tucker771
    Tucker771 [OP] Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    I am experiencing a general lack of power when driving my 04. It's started recently and I'm not sure why it is. Also, possibly related or not, my transmission has been shifting more roughly
  2. Jun 18, 2015 at 9:29 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    no cel codes? There are ALOT of causes of power loss. Gona need more info like what engine/tranny it has and any other symptoms. All the usual stuff include MAF. o2 sensors, plugs/wires, knock sensor harness, injectors.
  3. Jun 18, 2015 at 10:04 PM
    Tucker771
    Tucker
    Raleigh, NC
    3.4L automatic 4speed
    4x4 double cab
    O2 sensor cleaned recently
  4. Jun 18, 2015 at 10:42 PM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    1st I would do a drain and fill of the transmission. Maybe drop the tranny pan and replace the tranny filter and clean the magnets.
    Could you have fouled the O2 sensor while you were cleaning it or did you clean it after the problem Started?
    • Double check to make sure all the hoses and electrical connectors you touched recently are plugged in.
    • Plug in a code reader and see if you have any pending codes. Take it to any autoparts store if you don't have a code reader or buy one cheap online at Amazon or ebay. They have a Bluetooth OBDII reader that you can connect to you phone and you can download the free app "Torque". If you don't have pending codes it will make it difficult to narrow down.
    We may be able to help you more if you give us very detailed symptoms that you are experiencing.
  5. Jun 19, 2015 at 2:35 PM
    Tucker771
    Tucker
    Raleigh, NC
    @bawilson21 Everything I have touched has been plugged in correctly. No pending codes. I cleaned the MAF like 4 months ago and the symptoms started a month ago. drain and fill was done roughly 6 months ago by my trusted mechanic. The shifting is much worse when acceleration hard and it struggles a bit around 70 mph but once I get passed roughly 76 it accelerates better. I've lubed the driveline recently and the diffs and transfer case got a drain and fill aswell. Could it be plugs or wires? Sometimes the truck has a difficult time cranking. 138000 miles with stock plugs and wires, Brand new battery. I'm at a loss
  6. Jun 19, 2015 at 3:03 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    You should do a basic tune up. Plugs, Air Filter, oil change if you haven't had one in a while. If you have a K&N air filter, toss it in the trash and get a OEM type filter. If your plug wires look tired, replace those also.
  7. Jun 19, 2015 at 4:46 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I agree, look to the tranny for your issues, drain and check fluid for debris, if you find any drop the pan and replace the filter, refill and hope for the best, otherwise its tranny rebuild time.
    if your loss in power coincides with higher rpms that's another indicator its the tranny slipping
  8. Oct 4, 2017 at 8:09 AM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Hate to revive a super old thread, but did you ever figure this out? Or has anyone had success with solving an issue nearly identical to this? plz halp
  9. Oct 17, 2017 at 7:51 AM
    Tucker771
    Tucker
    Raleigh, NC
    wow this really is an old thread lol. It seemed to just kinda get better or ive gotten used to it im not sure which it is
  10. Oct 17, 2017 at 1:00 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Did I read back in 2015 you were still on original plugs at 138xxx mies? Isn't that way over due of replacement of the plugs?
  11. Oct 26, 2017 at 8:26 AM
    Tucker771
    Tucker
    Raleigh, NC
    yeah i ran them to about 140000 and switched them out along with wires. Didnt notice really any better performance when i switched them and the plugs that came out were more or less clean
