Lost 1" of height when I put on new wheels.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by meckleystephen, Sep 22, 2010.
  1. Sep 22, 2010 at 6:29 PM
    meckleystephen
    meckleystephen [OP] My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    Alright so here is the deal I recently installed Pro Comp 1079's(17 x 9) on my 06 AC SWB. They look great but the only problem is that after measuring the height of my truck I lost an inch all around. I am running 265/70/17 nitto terra grappler a/t and have billies all the way around,the front set at 1.75". The truck still sits perfectly level. I understand why I lost the inch, because the wheels are wider than the stock sport rims. It has been driving me crazy so much so that less than 48 hours after the install I ordered new wheels. FJ SE's to get my self back to stock height. Will these take my truck back to where it was before if I mount some 265/75/16? Or could I just put some 285's on the Pro Comps and get that height back. I understand the 285's may not be a possibility without alot of trimming. Here are some pictures of the truck before and after. Just looking for some input as if to anyone else has expierienced this and what they did. sorry for the rant
    before:
    after:
  2. Sep 22, 2010 at 8:31 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    After still looks good to me.
  3. Sep 22, 2010 at 8:35 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2002 Tacoma Xcab
    im confused as to how a wider rim caused you to lose height
    and 285 refers to a tires width...not height
  4. Sep 22, 2010 at 8:54 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    The sidewall of the tire is streached wider to reach the rim edge.
    This takes away heigth of the sidewall.
  5. Sep 22, 2010 at 9:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It wouldnt take away an Inch though....Maybe a fraction, but to loose 1" height from a tire/wheel, that means it would have had to shrink 2" in diameter.
  6. Sep 23, 2010 at 3:05 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    yup...and he also went from a 265/65/17 to a 265/70/17 that would have been ~1" taller and given .5" of overall height to the truck.
    OP, where are you measuring from? top of tire to fender, ground to fender, or center of hub to fender?
  7. Sep 23, 2010 at 3:42 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Now, thats just weird. "Who lowered his billies???"
  8. Sep 23, 2010 at 5:30 AM
    BGrutter
    BGrutter Well-Known Member
    Baron
    Kansas City, MO
    2010 4x4 DCSB TRD OR
    Rear-View Camera Mod, Anti-theft Tailgate, No Mud-Flaps, Diff Breather Mod, Color-matched Mirror/Handle covers, Front Valance mod, Phone/GPS/Camera mount, and Illuminated 4x4 Switch ToyTec Ultimate Lift Light Racing UCAs
    Stupid question probably, but have you double checked PSI on both sets? Possibly you were heavy in the first set and lite in the new ones?
  9. Sep 23, 2010 at 1:03 PM
    jhodge83
    SC
    265/70/17 is close to a 32"
    BTW, first #=width in mm
    second #=ratio of witdh to sidewall
    http://en.wikipedia.org/wiki/Tire_code#Explanation_of_tire_codes
  10. Sep 23, 2010 at 1:04 PM
    JimBeam
    JB
    2002 Tacoma Xcab
    wrong
    first number is width, second is height as a ratio to the width
  11. Sep 23, 2010 at 1:07 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    ^They are correct.
  12. Sep 23, 2010 at 1:13 PM
    Kdawwwg
    Kdawwwg Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    like i said ALLMOST POSITIVE [lol]
    so the stock tire is a 265/65/17 about a 31 in tire
    an 285/70/17 are 33s
    so just the 65 to 70 is the 2 inches,learn somethin every day:eek:
  13. Sep 23, 2010 at 1:15 PM
    jhodge83
    SC
    it's the combination of width AND ratio that make the overall diameter...
    265/65/17=31
    265/70/17=32
  14. Sep 23, 2010 at 1:16 PM
    JimBeam
    JB
    2002 Tacoma Xcab
    ehhh sort of
    the 2nd number is a ratio in terms of height compared to the width (first number)
    each brand will be slightly different but will be in a close range
    a 285/75/16 is considered a 33" tire, but many measure out at 32.x
    a 255/85/16 is also considered a 33" tire, but again often measure out at 33.xx
    a 285/75 is fat and wide where a 255/85 is skinny
  15. Sep 23, 2010 at 2:20 PM
    Imaking
    Imaking Taco Newb
    Isaac
    Pahrump, NV
    08 TRD Off-Road
    OME 885x coils, 5100's set at 0. Deaver 2" AAL and 5100s out back. AFE Pro Dry S drop-in, BHLM, '10 sport grille.
    :laugh: If anyone can GET the SE wheels
    :rant:
  16. Sep 23, 2010 at 4:26 PM
    meckleystephen
    Stephen
    York, PA
    I have been running these tires for almost 7k miles(just on sport rims), all I did was get new wheels. Right before I took it in I went around and measured and recorded everything for afterwards because I figured that it would drop it but a whole inch blew my mind. I do not know the exact width of the stock sport rim but I figured it was about 7.5-8???. It has been really bothering me and I dont think that it looks good at all. The reason I suggested getting a 285(I know thats the width) is because I figured that the wider tire would give me some of the height back like oh-man was saying.
    I didnt know for sure I was just throwing around some ideas. Oh and by the way the FJ SE's fell through as I kinda thought they would so now I am looking for an alternative wheel. I was thinking something that is 17x8 so I dont have to get new tires,and I can just run the 265/70/17's I already have. I was looking at the Pro Comp 7089's. The only reason I am sketchy of them is because the 1079's are not balanced properly and the alignment shop told me it was because the wheel does not have an outer lip for them to put weight on and this really bothers me because of the shake in the steering wheel. Is my alignment shop full of it. If I took them to the stealership could they do it? Im just trying to figure this out before I go out and buy another set of wheels and end up with the same wheel shake that I have now. Thanks for all the replies sorry that I confused some people.
  17. Sep 23, 2010 at 8:02 PM
    jhodge83
    SC
    stock sports are a 7.5" width....i got 7089s balanced w/ no issue...the fix is sticky weights in the inside of the rim.
    also, where are you measuring for the "height" difference?
  18. Sep 24, 2010 at 5:46 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    For him to lose an inch in height the tires would have to be 2" smaller in diameter. Somethings not adding up.
  19. Sep 24, 2010 at 5:53 AM
    poppasmurf009
    poppasmurf009 Active Member
    WI
    Stock 09 Access Cab V6 4x4
    Maybe if his tire pressure is way low...
  20. Sep 25, 2010 at 10:30 AM
    meckleystephen
    Stephen
    York, PA
    I am measuring from the center of the bottom of tire(where it meets the ground) to the right where the fender flare starts. My thinking is though it doesnt really matter where I measure from as long as I measure from the same spot everytime, or is that wrong? In the front I measure from the ground to the top of the bottom grill.
