lost 20% fuel economy by stepping up one size on my tires. is this normal.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bugchucker, Jan 4, 2015.
  1. Jan 15, 2015 at 6:18 AM
    #41
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
  2. Jan 15, 2015 at 9:08 AM
    #42
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    The good news for you is gas is $0.80/L in Canmore ;), and yes your getting "normal" mileage.
  3. Jan 15, 2015 at 9:13 AM
    #43
    Mizzouborn
    Mizzouborn Well-Known Member
    Tampa, FL
    06 Tacoma PreRunner
    Thorley Headers Dual Exhaust Flowmaster 40s Bilstein Shocks/Struts K&N Air Filter
    Gotcha....the link showed me that my -4% adjustment in my ScanGauge was definitely a little high but I'm good with a worst case scenario.
  4. Jan 15, 2015 at 2:25 PM
    #44
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The larger the tire the slower the speedo will read. A larger diameter tire will spin slower than a smaller diameter tire.
    Try to visualize 2 circles. One large and one small. If you marked a starting point on each circle and rotate them, which one will make a full rotation first? The smaller one will. The larger circle has more area to cover. Hence the larger diameter tire will spin slower giving you a slower speed reading.
  5. Jan 17, 2015 at 9:15 AM
    #45
    YYZ
    YYZ Member
    YYZ
    SLC UT
    SR5 Sport 4x4
    A.R.E. Shell
    Here are the results of my RPM Speed and throttle response test. Not to get OT but related so as to index 'cruising' speed at certain RPM's (for my Tacoma model) and for comparison of what might be considered hard driving (throttle response)
    Truck - '07 Access cab sport 4.0 manual SR5 4WD 30kmi @ 4,300ft elevation
    Mods - Shell, Bilstiens+AAL=2in lift, Tires BFG AT KO 165/70/R17 10ply, removed 2nd charcoal engine filter, otherwise stock
    Test conditions - start cruising speed measured off GPS for true speed (it matched perfectly to my stock tires and guage before I went to the BFG's) - start speed was from a dead cruise to eliminate intertia effects, flat smooth road, no wind, 1/3 tank of gas. No shifting, remained in gear shown. At least 3 attempts to get an avg. seconds figure
    Gear / RPM / Sec's to accel 10mph at WOT
    30-40mph
    2nd / 2600 / 2.3secs
    3rd / 1925 / 3.3secs
    4th / 1500 / 4.75secs
    40-50mph
    3rd / 2500 / 3.5secs
    4th / 2000 / 4.5secs
    5th / 1575 / 6.4secs
    50-60mph
    4th / 2500 / 5secs
    5th / 2075 / 6secs
    6th / 1750 / 9secs
    60-70mph
    5th / 2500 / 7.75secs
    6th / 2050 / 8.75secs
    70-80mph
    5th / 2950 / 7.3secs
    6th / 2500 / 12.25secs
    At the 60-70 test I didn't go below 2050 knowing there be be little to no acceleration response below that (took 12.25 seconds just to get from 70-80 in 6th) so I didn't really test 1600 rpm at 60mph.
    I just got my new tires and haven't put enough miles on them to get reliable new mileage readings (but definately lower than 17). I will follow up in this thread after a few tankfuls.
