Lost all lights on 2004 Tacoma
Discussion in 'Technical Chat' started by Toygirl, Jan 15, 2015.
  1. Jan 15, 2015 at 4:15 PM
    Toygirl
    Toygirl [OP] New Member
    Colorado
    2004 tacoma and Rav4
    just had a check engine light diagnosed with O2 sensor and the mechanic reset it. Now I've lost all lights interior and exterior. Of course you know the check engine is still on ironically. Pretty sure my problem is related to the reset - but any and all advice will be appreciated since I am currently away from home.
  2. Jan 15, 2015 at 4:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check fuses. Look for pinched or burned wiring and check ground connections are clean and tight. Maybe try another battery. Good luck!
  3. Jan 15, 2015 at 4:42 PM
    Toygirl
    Colorado
    Thanks
  4. Jan 15, 2015 at 4:55 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    If the truck starts and runs, perhaps critters have dined on some wiring under your truck. It wouldn't be the first time.
  5. Jan 17, 2015 at 2:32 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    You might also check for battery/ground terminal corrosion. Could also be a disconnected ground wire, especially if he replaced the sensor. Do the headlights work?
