Lost chrome wheel moldings, stripping
Discussion in '1st Gen. Tacomas (1995-2004)' started by rybern, Jul 28, 2017.
  1. Jul 30, 2017 at 3:39 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Doesn't look like you're wired for mirrors unfortunately. 2 pins for pos/neg of speaker and 1 wire for the courtesy light trigger.
    I do wonder what that connector is for though. Maybe you know, @mechanicjon?
  2. Jul 30, 2017 at 3:59 PM
    rybern
    rybern [OP] Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    You can see if at the bottom of the 2nd photo in case someone is curious.
  3. Jul 30, 2017 at 5:25 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Locker computer has 10 pins, not 6.
  4. Jul 30, 2017 at 6:40 PM
    rybern
    N Alabama
    OK, now its a mystery.
  5. Jul 30, 2017 at 8:10 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    From what I understand the locker on non 4WD vehicles had its own computer, while the 4WD vehicles with the locker just used the 4WD computer. Is that true?
  6. Jul 31, 2017 at 3:21 AM
    rybern
    N Alabama
    For the record, my truck is a 2000 4wd, non-TRD.
  7. Jul 31, 2017 at 6:43 AM
    nzbrock
    Noah
    San Marcos, TX
    Nope, not true. There are two computers regardless of 4WD or Prerunner. The locker computer is called the 4WD Control ECU, and the 4WD computer is called 4WD ECU. Although I have seen documentation where they are both called 4WD Control ECU. I know, very confusing.
    The locker computer is located in the driver kick panel and is either brown or black depending on the year. The 4WD ECU is somewhere in the dash.
    Hamer95USA and Dalandser like this.
  8. Jul 31, 2017 at 10:46 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Well damn that's confusing... so if I had a PreRunner the rear locker computer would be called '4WD Control ECU'?
  9. Jul 31, 2017 at 11:06 AM
    nzbrock
    Noah
    San Marcos, TX
  10. Jul 31, 2017 at 11:20 AM
    BartMaster1234
    Tyler
    Flux Capacitor
  11. Jul 31, 2017 at 11:41 AM
    nzbrock
    Noah
    San Marcos, TX
    I got all the wiring from the donor truck and pulled the locker wires from the rest. Then I used a 6 pin connector I got on Amazon for the under seat connection. I talk about it a little bit in that post.
  12. Jul 31, 2017 at 12:32 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Were all the wires on the 4WD control computer used for the rear locker?
  13. Jul 31, 2017 at 12:55 PM
    nzbrock
    Noah
    San Marcos, TX
    The 4WD control ecu is only for the locker, nothing else. It gets it power from the 4wd 20amp fuse and connects to the 4wd ecu to only lock in 4 Low (4wd models). There is a separate ECU just for 4wd components.
  14. Jul 31, 2017 at 1:09 PM
    rybern
    N Alabama
    So, what's the verdict on this connector that I thought was for the mirrors? It isn't connected with anything. Would it go to the locker if I wanted to install a factory E-locker? This is toward the bottom behind the drivers side kick panel.
  15. Jul 31, 2017 at 1:11 PM
    #35
    nzbrock
    Noah
    San Marcos, TX
    Nope, not for the locker as I stated earlier. Locker connector has 10 pins.
  16. Jul 31, 2017 at 1:14 PM
    #36
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Cruise control or power doors? :notsure:
  17. Jul 31, 2017 at 1:14 PM
    #37
    rybern
    N Alabama
    Ah, that's right. I forgot. Thanks. It's probably for the air conditioned seats option. ;)
  18. Jul 31, 2017 at 1:15 PM
    #38
    rybern
    N Alabama
    I have cruise, pwr locks/windows and this connector isn't hooked to anything.
    Dalandser[QUOTED] likes this.
  19. Jul 31, 2017 at 1:17 PM
    #39
    nzbrock
    Noah
    San Marcos, TX
    Could be for ECT since you have a manual.
    Dalandser likes this.
  20. Jul 31, 2017 at 1:40 PM
    #40
    BartMaster1234
    Tyler
    Flux Capacitor
    That makes so much sense now.
