Lost dashboard lights
Discussion in 'New Members' started by rovalfam, Dec 31, 2010.
  1. Dec 31, 2010 at 3:51 PM
    rovalfam
    rovalfam [OP] New Member
    Riverside, California
    01, prerunner
    The lights were working fine until yesterday (12/30/2010). I replaced the battery and I have no lights in the dashboard now. I checked the fuses under the dash:OK. I turned the dimmer knob, nothing works. Is there a dedicated fuse somewhere else for the dash light? If not, maybe it was a coincidence and I just have a bad light bulb. Whereabouts is it located and how do I replace it. Thanks.
  2. Dec 31, 2010 at 4:30 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    Do you have tail lights?
    No dash lights can be an indicator of no tail lights as they are usually fused off the same fuse.
    I doubt you have just one dash light bulb.
  3. Dec 31, 2010 at 7:05 PM
    rovalfam
    01, prerunner
    Thanks for the reply. I just checked the tail lights, they work.
  4. Dec 31, 2010 at 7:07 PM
    rovalfam
    01, prerunner
    I think I'm writing stuff in the wrong place. Thanks for the reply. the rear lights work, I just checked.
  5. Dec 31, 2010 at 10:48 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    You have to check the fuses under the hood. See your manual page 407.
