Lost Faith - 6SPD and toyota
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cstephan, Aug 29, 2012.
  1. Aug 29, 2012 at 11:50 AM
    cstephan
    cstephan [OP] Jack Of All - Master at none
    Hendersonville, Nc
    17 Taco TRDOR -DCSB- Gov. Controled Special
    Hold my BEER and WATCH THIS
    Hey TW..
    I hate to have a bad experience and bad news. I have a grinding noise when engaging 4th gear. Sounds like and feels like a synchronizer in the 4th gear, I have the TRD Quick Shifter. Dealership told me something is wrong, and called in an “engineer”, “engineer” hears it under a slightly quicker shift, only gear that this happens in. Tells me its normal.. I know its not, I called Toyota customer service, and they keep telling me they stand behind the “engineer” and there is nothing they can do. I only have 27,000 miles on this truck, and I know there is a problem, I baby this truck, and I am easy on it because I wanted it to last. I don’t know what do you guys? Can someone please help, I am veryunhappy with the service, and support, and I just want it fixed.. can someoneoffer any advice other than trading it in on something else?
  2. Aug 29, 2012 at 12:01 PM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    Drive it till it breaks then you can go back and tell tell them you were right and that it should all be covered
  3. Aug 29, 2012 at 12:33 PM
    cstephan
    Hendersonville, Nc
    i wish it was that simple. after 60,000 they could care less
  4. Aug 29, 2012 at 12:38 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'm missing the point....Toyota isn't at fault here but it simply sounds like a shitty dealer.
    Solution: Find another dealer. Get them to warranty it or document the damage.
  5. Aug 29, 2012 at 12:56 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    did they give you a receipt stating there was no problem? save that.
    now take it to the next toyota dealership down the road..see what they say. keep that receipt too...if it should blow up, you can get it fixed past the warranty, because you kept the paperwork, and documented it.
    personally, i would have had the engineer pull out another 6 speed and prove that it was normal.
  6. Aug 29, 2012 at 1:01 PM
    cstephan
    Hendersonville, Nc
    this Toyota engineer is for our region, and he is the one that says, yes to it getting fixed or not. he put in his paper work, normal condiction
  7. Aug 29, 2012 at 3:31 PM
    ItalynStylion
    Steven
    DFW, Tx.
    And? Go to another dealer and see what they say. Some dealers will run it up the flagpole and see if they can get someone to shoot it down. Other dealers will just fix it. Can't hurt to try. What do you have to lose?
    Think about the guys who went to the dealer asking for the rear spring TSB; some got denied and went to another dealer and they got it done no problem. I'd suggest you try the same thing.
  8. Aug 29, 2012 at 3:34 PM
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    I have the same experience, 2012 6spd grind in 1st, clearly crap synchro - Toyota offering the official blow off from the Field Technical Rep "it's normal". Yes the field rep shows up after you call 800-331-4331 and open a case file with Toyota.
    I'm getting the same crap response for the drive train shake, which I theorize is related to the trans is prob worsening. "but that's normal too".
    Meanwhile my 150k mile (+ 1 rebuilt auto trans after 10 years and 140k with towing) F350 is fine.
    "Normal" for Toyota now is occasionally selling shitty products and no remedy. They only got 1 chance to burn me. I won't own another one.
  9. Aug 29, 2012 at 6:04 PM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    Being an engineer and knowing engineers that work for many different industries, it makes no sense to me that an engineer would be trying to diagnose a problem...the term engineer is being used very loosely to make people who are not really engineers sound important and smart...usually they are neither
  10. Aug 29, 2012 at 6:11 PM
    badger
    badger Well-Known Member
    07 SR5
    What oil is in your transmission?
  11. Aug 29, 2012 at 6:18 PM
    badger
    07 SR5
    I'm an engineer as well, and you are correct. These guys are probably mechanics promoted to "engineer" and tasked with denying every claim they can. It's just a ploy. Aside from that, Toyota is well aware they have issues with the 6 speed. They just won't own it, and It has wounded my faith in the brand as well.
  12. Aug 29, 2012 at 7:00 PM
    zonataco
    zonataco Well-Known Member
    I was told it was a cultural thing...not wanting to admit to a mistake.
    Nikon is having a lot of probs with their newest digital camera and their auto focus system.
    Although they fix them when sent in for service, they will not acknowledge the problem or offer an explanation for what was wrong or even what was done to fix the problem.
    I hope you get some satisfaction.
  13. Aug 29, 2012 at 10:05 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Agree with badger.
    I know you shouldn't have to do this on a truck with 27k but you are close to your 30k service anyway so dump the factory gear oil and run redline mt90. It'll cost you about 30$ to do so and MAY take away that grinding.
    I'm not overly happy about the 6spd either. I've got a similar thing going on with mine in 5th gear. Switching to the MT90 very soon, hopefully that gets rid of the problem. If not I've got 59k on the damn thing and I might take it to Toyota to document it at least. At least they built solid engines for these trucks.
    Good luck.
  14. Aug 29, 2012 at 10:06 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    mine grinds going into 5th :(
  15. Aug 29, 2012 at 10:12 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i have a question for toyota :)
    why did they replace a great transmission like the one found in the first gen pick-up and tacoma with this turd of a trans?
    the 5 speed i drove last week in a 1986 4 runner with over 270k on the clock shifted better than all of the 2nd gen tacoma's i have driven :confused:
    a little off topic but, it's a step back in my book and a rather large one at that. don't get me wrong i have complete confidence in all of them meaning i think they are mechanically sound. but, they are no where near as easy to live with on a daily basis.
  16. Aug 29, 2012 at 10:24 PM
    BMOC
    Paden
    Phoenix, AZ
    DONT LAUGH AT US!!
  17. Aug 29, 2012 at 10:31 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I know more mechanics that would be better engineers than engineers are at being engineers:eek: Engineers tend to over think a problem when its very easily fixed by thinking mechanically. just my experience with them. A promoted mechanic to engineer trumps an engineer stright out of school anyday in my book. most engineers even see how things actually work in the real world they just look at paper drawings and cad all day...
  18. Aug 29, 2012 at 10:33 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    every 2nd gen manual trans i have driven has felt like garbage to me.
    fucking unbelievable lol the 86 runner shifted like a car my 5 speed shifts like a garbage truck lol
    i would just get used to it drive it until it breaks then fix it the new manuals are not great but, they work all the same.
  19. Aug 29, 2012 at 10:38 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
  20. Aug 29, 2012 at 10:39 PM
    BMOC
    Paden
    Phoenix, AZ
    :mad:
