Lost fob - is it possible to "forget"?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Just_Tombo, Jan 14, 2023.
  1. Jan 14, 2023 at 9:46 AM
    Just_Tombo
    Just_Tombo [OP] Well-Known Member
    2003 prerunner TRD DC 3.4
    2003 Tacoma - a key and fob went missing. Is it possible to reset the truck so that the lost fob would no longer open the truck if found? I'm concerned that if it were recovered near my primary parking spot that a potential crook could use it to steal my truck. I am leaving the garage door out of the truck as a precaution for now. TIA
  2. Jan 14, 2023 at 9:49 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Not 100% on this but maybe if you get a new FOB and they program it to your truck maybe the lost one will no longer work to open your truck :notsure:
    Taco y mas likes this.
  3. Jan 14, 2023 at 10:37 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Shouldn’t be a problem. Make sure you buy a fob with the correct FCC#. Look at your keyless entry module, it should have the corresponding fcc#.
  4. Jan 14, 2023 at 10:44 AM
    jrallan26
    Iowa
  5. Jan 14, 2023 at 11:14 AM
    Just_Tombo
    My question was about whether I can make my truck forget the lost one (because I'm concerned it could be found and used to gain access to my truck) Any comment on that?
  6. Jan 14, 2023 at 11:15 AM
    Just_Tombo
    That'd be nice if it's true. Hoping someone in the 100% "know" could chime in
  7. Jan 14, 2023 at 12:01 PM
    Chipped Paint
    Chipped Paint Member
    Arkansas
    04 Tacoma Xtra Cab TRD
    The video says you can clear all existing remotes.
    jrallan26 and Just_Tombo[OP] like this.
  8. Jan 14, 2023 at 12:12 PM
    Just_Tombo
    Good looking out! I didn't watch the video the whole way the first time because I assumed it was just another how to on programming. I still have another fob that I's already programmed, so I will test the procedure he suggested and report back. Thanks @jrallan26 for the post
  9. Jan 14, 2023 at 12:14 PM
    jrallan26
    Iowa
    No problemo. Just one thing. Do not buy a fob from the dealer, they will gouge you. You can find a fob online cheap.
  10. Jan 14, 2023 at 12:15 PM
    jrallan26
    Iowa
    you beat me to it!
  11. Jan 16, 2023 at 8:55 PM
    Just_Tombo
    Thought I would follow up - the technique outlined in briefly in the video did NOT solve my issue. What I really needed was to delete all fobs from my trucks memory. A little targeted searching lead me to this technique: follow all steps in video except at the end of the sequence after closing door and inserting the key, turn key from lock to on Five times, then removing the key. The truck will cycle the locks open and closed 5 times, then open your door to complete the task. This sequence will delete all stored fobs. Then, simply add your existing or new fobs back in as described in the video.
    I did have an extra fob that did not go missing, and so I was able to confirm: the previously programmed fob still in my possession no longer worked after. Then I added it back in by following steps in video.
    I am now confident someone won't find my fob and have easy access to my truck.
    TACOTU3 likes this.
  12. Jan 17, 2023 at 11:41 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You know they can slim jim in 10 seconds or less right? If you're worried about them getting to the garage door opener, it's no safer without a working FOB in their hands.
    Edit: And for whatever it's worth, if they were smart enough, they could just intercept your fob signal or garage door signal pretty easily. Even if you have a home security camera, all you're likely to establish is that someone did indeed break into your garage and take stuff.
  13. Jan 17, 2023 at 11:46 AM
    Just_Tombo
    Just trying to help keep honest people honest. Career criminals definitely don't need a fob to gain access to my vehicle. I still definitely feel better that the lost fob no longer opens my truck. These fobs are powerful! I can unlock my truck from a half block away. At this point, it is unclear where and when the fob was lost, a real possibility is that it was lost near my house (near my primary parking spot). If a random passersby picked up the key and pressed the fob, it is no longer obvious which toyota on the block it will unlock.
  14. Jan 17, 2023 at 12:10 PM
    Chipped Paint
    Arkansas
    Where did you end up getting a replacement fob from? I haven't had one in 8 years but I'm starting to miss the unmistakable Toyota beep
  15. Jan 17, 2023 at 12:28 PM
    Just_Tombo
    My truck came with one, and I ended up buying a second one from the dealer. I tried 3 different ones from Amazon, one worked, but was much more sensitive to range (more than 10 feet from the truck and it wouldn't open). Returned all of them and bought one from the dealer. I think I payed $50 for it. I will buy another one from the dealer, since the person who lost the key and fob said they would pay.
    Hope that helps
