Lost front brakes...
Discussion in '1st Gen. Tacomas (1995-2004)' started by STLharry, May 2, 2010.
  1. May 2, 2010 at 7:14 PM
    STLharry
    STLharry [OP] Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    So I went to play in the mud today (in this thread), but right as I went to leave I noticed the brake pedal suddenly went all the way to the floor and the truck had a hard time stopping. After driving a bit, I stopped and checked the brakes.
    There is no fluid loss, at least not as of now.
    I am guessing that it is a total loss of the front brakes because the rotors were not clean...they still had a thin layer of mud on them (they would have been cleaned off by the pads if they worked).
    Any help? I need a quick fix so I can drive/work with this truck this truck until the new one is finished in a month...
  2. May 2, 2010 at 7:18 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    id try a pressure washer to em see if that does anygood...
  3. May 2, 2010 at 7:20 PM
    STLharry
    Harry
    VT
    Ya I was thinkin that...maybe they were somehow stuck? But idk how that would explain the pedal going to the floor still though.
  4. May 2, 2010 at 7:26 PM
    clarkie152
    MA
    2016 4Runner Trail
    if you hold the brake down and gas it...do the brakes hold? they should hold the truck...
  5. May 2, 2010 at 7:28 PM
    STLharry
    Harry
    VT
    Well the the rear brakes work so it should hold ok...but I wouldn't drive a long distance.
  6. May 2, 2010 at 7:32 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    If the pedal went to the floor, you have a leak.
  7. May 2, 2010 at 7:35 PM
    STLharry
    Harry
    VT
    ...But I parked at a gas station for 20 minutes and didn't get any leaking brake fluid. Also idled and somebody pushed the pedal while I checked underneath. No fluid loss...
  8. May 2, 2010 at 7:36 PM
    clarkie152
    MA
    2016 4Runner Trail
    isnt toyota buying this anyways? i thought i remeber seeing something about it
  9. May 2, 2010 at 7:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Huh, weird. I would think that the only way the pedal could go to the floor is if there is a leak in the system.
  10. May 2, 2010 at 7:51 PM
    STLharry
    Harry
    VT
    That's what I thought! So I checked for leaks...!
  11. May 2, 2010 at 9:21 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    That doesnt make sence. :confused: If there isnt any leaks there should be pressure in the brake lines.. Im sure theres some tips to check. But maybe you missed the leak?
  12. May 2, 2010 at 9:23 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    What about water/ mud in the lines and expanding into air, you may want to bleed through your lines.
  13. May 2, 2010 at 9:28 PM
    STLharry
    Harry
    VT
    Good suggestions thanks. I was planning to clean/bleed Tuesday and see what happens.
  14. May 3, 2010 at 10:31 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    well Im thinking your master cylinder failed its a 2 stage and the 1 stage failed internally sorry but thats what I figure
  15. May 3, 2010 at 10:33 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  16. May 3, 2010 at 10:39 AM
    STLharry
    Harry
    VT
    Well that's what I would say except I replaced the master cylinder about 3 months ago...so maybe I got a bad one/didn't install it right? I don't know.
  17. May 3, 2010 at 10:48 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    x2:thumbsup:
    This has happened to me before!
  18. May 3, 2010 at 10:51 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    That makes it sound even more likely: infant mortality is what we call it.
    Was it a re-man'd part?
  19. May 3, 2010 at 1:06 PM
    STLharry
    Harry
    VT
    Ha...yeah I think it was. I didn't care about the quality because the truck is going into Toyota for the frame recall in about 3 weeks (and I already have the new truck, a 2001 V6 TRD)...I just wanted the problem fixed as cheaply as possible. Very unlike how I usually approach it.
    Should I even bother fixing it?
