Lost in the sauce
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ChW94, Sep 7, 2017.
  1. Sep 7, 2017 at 9:34 AM
    ChW94
    ChW94 [OP] New Member
    Hello so got my new 2017 tacoma back in May and I want to start working on it to eventually take off road but don't know where to start been reading the thread and have a general idea of what I'd need to get depending on what I get.
    So for starters I want to get fox coilovers but saw in a post someone had coilovers in the front and leaf springs in the back, why is that? Is it better that way or just preference and what does it do to make you enjoy it that way? Do you always have to change the uca or is it dependent on what size coilovers you get? Also I would like to put my tacoma on 12.5x30x20 with 2" wheel spacers, who makes good stamped wheels and who makes good off roading tires that have aggressive tread? Thank you for any advice
  2. Sep 7, 2017 at 9:38 AM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Welcome to TW. :wave:
    From the factory the Tacoma has independent suspension in the front with coilovers and leaf springs in the rear. So to lift it you need to modify the suspension accordingly.
    I don't have much experience with lifts so I won't be any help there.
  3. Sep 7, 2017 at 9:39 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Your truck comes stock with coilovers in the front and leaf springs in the back. Nobody did that. Toyota did it. As far as the rest of the post, you will rub all day every day unless you cut and pound and trim lots of stuff.
  4. Sep 7, 2017 at 9:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    Take it off road now. Then add/change things as you find need to improve your experience.
    Spending money in advance of knowing how capable the truck is for how you are using it is just playing pin the tail on the donkey. How lucky do you feel?
    I will offer that tires are typically the 1st consideration. But they don't have to be jumbo, just better than stock. What you are considering is a street queen-look-tough-poseur setup, not a real off road unit. No offense.
    If you build the truck for how you use it 80+% of the time, you'll be much happier with it than if you build it for the occasional 20%.
    And your wallet will thank you too.
    beers@1600 and hiPSI like this.
  5. Sep 7, 2017 at 9:52 AM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    Oops, I must be doing it wrong. I got mine a few months ago and have taken it off road several times without working on it at all.
    hiPSI likes this.
