Lost my only key... help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CharlesPNG, Aug 23, 2023.
  1. Aug 23, 2023 at 11:49 PM
    CharlesPNG
    CharlesPNG [OP] Active Member
    Chuck
    2020 Cement Tacoma TRD OR M/T DCSB
    ARE truck cap, Drop Steps, Pedal Commander, Infinity Reference front door speakers, UPTOP Overland roof rack, 32" LED Light bar, Cali Raised ditch lights, Pro-grille
    I have a 2020 TRD OR M/T.
    Key is the fob/key combo - the engine is started using the key, not push-button. I purchased from a dealer used, and it only came with one key. My dumb ass never got a backup key. Now the only key I had is MIA.
    Dealer quote: ~$800. Requires vehicle on-site, meaning a tow since obviously I can't drive it.
    Any suggestions? DIY? Mobile locksmith? The couple I contacted said "nope, can't do that tacoma/year."
    I would resort to just about anything to avoid the swindler - I mean dealer - from cashing in on this.
  2. Aug 23, 2023 at 11:56 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    You checked the couch cushions in the house? It couldn’t have gone far.
  3. Aug 24, 2023 at 12:01 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Did you buy new? The dealer owes you the second key, maybe?
    Time to collect it... if so...
    asuchemist, Stevie17 and GarlicFarts like this.
  4. Aug 24, 2023 at 4:12 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    States he bought it used. Used typically implies sold as the fuck is, unless it is a certified vehicle.
    Stevie17, Gunshot-6A and Chew like this.
  5. Aug 24, 2023 at 4:28 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Stab in the dark but I would search the truck,under and inside. The previous owner might have hidden the other key in case they lost a key while on an adventure.
  6. Aug 24, 2023 at 6:45 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it's gotta be somewhere around the house. i mean, you can't drive it without the key.
  7. Aug 24, 2023 at 6:49 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    How drunk were you? Check the freezer and microwave.
  8. Aug 24, 2023 at 6:49 AM
    Silver-Taco1
    Silver-Taco1 Well-Known Member
    Get quote from a locksmith and have at LEAST two extra keys made. I have three extra keys for all of my vehicles, it's cheap insurance.
    Is the key fob in the truck? The dealer can cut you key to get in the cab from your VIN. That should only be about $20.
    Stevie17, Gunshot-6A and McHale like this.
  9. Aug 24, 2023 at 7:03 AM
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    Is it possible your truck is able to detect key fob near-by? If so, that's a great clue in starting your search. If not, than just look randomly, anywhere and everywhere. Once found, I recommend tagging your keys with some loud/bright preventing another loss.
    Good luck!
    Stevie17 likes this.
  10. Aug 24, 2023 at 7:11 AM
    TacoGranny
    TacoGranny Well-Known Member
    2020 TRDOR DCSB Cement 6MT
    33's, Sliders, Skid Plates, Softopper, ATH rear bumper
    Probably requires a trip to the dealer, it sounds like you have the H-key (no push button), they still have a little transmitter inside of them to let the truck know that the key is the correct one, paired to the ECU. I don't see how you would get around a trip to the dealership for a new matching key. Get 2 while you're at it.
  11. Aug 24, 2023 at 7:43 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Take your vin and proof of ownership (e.g. insurance card, registration, etc) to a dealer and they can cut or obtain a key for you. Less than $100.
    Call the dealer parts dept before you make the trip in order to validate if any other document is needed.
  12. Aug 24, 2023 at 7:53 AM
    Silver-Taco1
    That will get them in the cab but it won't start it.
  13. Aug 24, 2023 at 8:01 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    If the truck is home, so is your solo key! Do $800 worth of searching!
  14. Aug 24, 2023 at 8:06 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    You left it inside the Tacoma
    Stevie17, wilcam47 and Gunshot-6A like this.
  15. Aug 24, 2023 at 8:07 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    Exactly, this worked a dozen years ago, on cheaper cars, but there is more going on with a modern key than just the pins lining up and the key rotating in the cylinder.
    See if you can find someone local who has something like an XTool D8 or Techstream. They can program a cut key for you. Maybe they won't charge you as much as the dealer.
    RedWings44 likes this.
  16. Aug 24, 2023 at 8:09 AM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    Exactly. If you pulled into the driveway and walked away, the key needs to be somewhere where you walked.
    To that end:
    1. How long since the vehicle has been driven?
    2. Has the trash been taken out? (I've had a friend throw his wallet in the trash since he was carrying trash in his hand at the same time, and just tossed both the trash and his wallet into the bin...)
    3. Anyone else use the truck after you?
    4. Are the doors unlocked? Can you get into the truck?
  17. Aug 24, 2023 at 8:16 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    New h chip key for $100....in what world lol
    Stevie17 and TexasG like this.
  18. Aug 24, 2023 at 8:22 AM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    Yep new gm vehicles are the same way, happens just about every week at work. Gets pricey with towing, the transmitter and the key. I’d keep looking first. Any chance the dealer is close and can send a tech with their laptop to you to save on the tow bill?
  19. Aug 24, 2023 at 8:26 AM
    ULURU
    Labor and monetizing the key programmer...
    From my understanding, most DIY solutions are predicated on having one working key (or two) that will start a car. If you don't have at least one working key, I think the onboard immobilizer needs to be wiped and reprogrammed from scratch.
    Chipped keys for my old Escape could be cut by anyone. As long as I had two working keys, I could add more keys. The keys were like $25 each, and I paid a locksmith a few bucks to cut them, and programmed them myself.
    I found aftermarket fobs for my Taco for like $35-40 each. Since I had at least one working key, I could rent Tom's Key programmer and 1) erase all keys but one, and 2) add up to three additional keys (for a total of 4 smart fobs).
    When you're one deep, you're none deep....
  20. Aug 24, 2023 at 8:29 AM
    dietcokefiend
    dietcokefiend Well-Known Member
    No easy way around it. Given the cost and the fact they are somewhere in your house... might even be worth hiring kids or outside help to do a top-down search of your house.
    Stevie17, Barsoom and Chew like this.
