Lost on hot start issues...
Discussion in '4 Cylinder' started by eclipse22, May 28, 2018.
  1. May 28, 2018 at 11:26 AM
    eclipse22
    eclipse22 [OP] Well-Known Member
    Marcin
    I've done a lot of research and still trying to debunk why my 2.7 2006, on very hot days doesn't do a nice consistent start, kind of chokes up and then starts to run. When driving, hit up some shopping come back and start it, cranks like half a second and starts. Been doing this since new has 100k miles. Only happens when it's hot 30+ Celsius here in canada.
  2. May 28, 2018 at 11:34 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    30 C ? What’s that in American?
    wilcam47 likes this.
  3. May 29, 2018 at 12:00 PM
    eclipse22
    Marcin
    Drove truck, parked for 2 hours, very hot outside. Took about 4 seconds of cranking but gurgled to a start...
  4. May 29, 2018 at 12:03 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    To convert temperatures in degrees Celsius to Fahrenheit, multiply by 1.8 (or 9/5) and add 32.
    eclipse22[OP] likes this.
  5. May 29, 2018 at 12:04 PM
    wilcam47
    Will
    Bourbon state
    check for leaky injectors...
  6. May 29, 2018 at 1:46 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I think he said it was doing this since new?
  7. May 29, 2018 at 2:46 PM
    eclipse22
    Marcin
    Yes it has been doing it since new... But long story short this truck sat in a garage since new for 5 years before I bought it
  8. Jun 1, 2018 at 11:19 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    A brand new truck sat in a garage for 5 years? Dang. Besides making me want to cry, sitting unused for very long periods can cause a number of issues. Glad to hear you've been researching it as much as possible. The "crank like 1/2 second and it starts" is a normal start. Cranking for 4 seconds and gurgling to a start" is a problem. I agree the injectors are suspect, but I also suggest checking/cleaning the mass airflow sensor and throttle body. Is the battery good? A battery can be on its way out and still start your engine... electrical issues can mask themselves as other issues, and be far more frustrating to diagnose than mechanical woes. And how is the air filter? Any vacuum leaks? Good luck.
  9. Jun 12, 2018 at 7:24 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    OP long start on mine recently within the year was cured by a set of replacement injectors. Five O Motorsports has replacement injectors at a reasonable cost.
