Lost power after installing air intake?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MooseMan315, May 18, 2021.
  1. May 18, 2021 at 4:57 PM
    MooseMan315
    MooseMan315 [OP] Member
    2017 Taco TRD Sport 6-Speed
    Hi all. So I installed an Injen EVO2200 air intake system a few weeks back and everything was great. More low end power, slightly better throttle response, great sound, etc.
    A couple days ago tho it seemed to have lost power while accelerating through the gears. On-ramps aren't quite as much fun now.
    I'm assuming the computer recognized the difference in air flow and is compensating by choking it back? Anyone else run into this? How do I overcome it?
    2017 3.5l TRD Sport 6-speed manual.
    Thanks in advance!
  2. May 18, 2021 at 5:37 PM
    MooseMan315
    Or is there a thread on this already?
  3. May 18, 2021 at 5:45 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    This simplest answer is pull the aftermarket stuff.
    Knute, kahanabob, Rainoffire and 7 others like this.
  4. May 18, 2021 at 5:49 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    The computer adjusted to the air intake change. You need a tune to compensate for the increased air. You will get lower Mpg also. More air needs more fuel.
    hiPSI likes this.
  5. May 18, 2021 at 5:56 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Could be an air leak somewhere:
    Make sure the coupler clamps are tight.
    Make sure the O-ring for the MAF sensor is seated correctly and hasn't squeezed out. Make sure the MAF sensor screws are tight.
    Remove the PCV vent hose; look down the spigot (with a mirror if needed) and make sure it isn't blocked. Reinstall the PCV vent hose and make sure the clamp is tight.
  6. May 18, 2021 at 6:06 PM
    MooseMan315
    Good info, thanks
  7. May 18, 2021 at 6:23 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Interesting. Never had “power loss” on any of my vehicles after installing aftermarket intakes.
  8. May 18, 2021 at 6:35 PM
    dagobert
    dagobert Well-Known Member
    You only experience loss if you have a leak after the MAF.
  9. May 18, 2021 at 6:48 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Don't pick and choose answers man. Pull the mod. See what happens. Report back.
    You will be surprised. Don't go moddin if you don't know about moddin.
    MJTH, 9th, Skydvrr and 1 other person like this.
  10. May 18, 2021 at 8:11 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Low end power boost...Mkay.
    Better throttle response...Right.
    Take it off and go back to stock.
  11. May 18, 2021 at 9:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Maybe the placebo effect wore off. :D But the extra growl from the resonator delete should still be present.
    I run a Volant CAI for the sound and the clear lid (so I can visually inspect the filter without opening the lid).
    Junkhead, jmneill and Skydvrr like this.
  12. May 19, 2021 at 6:43 AM
    MooseMan315
    I mean i understand that the new intake was going to throw off the diagnostics and it would try to compensate for the change, I knew that going in to it. I'm mainly reaching out to see if anyone has advice or experience with any tools or software I can get to connect to the truck to balance it out
  13. May 19, 2021 at 7:04 AM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    I’m not saying this is absolute law but GENERALLY newer cars are pointless to modify. Yeah, manufactures can’t really lie if something adds power but at what rpm and under what conditions? I always tell my customers don’t waste your money on intakes, filters or other similar products. Manufactures don’t bother with direct injection, variable valve timing, variable intake runners and so on, just to leave “easy” performance on the table. Yes, there is a lot more science to making power than just having more flow but another highly generalized statement is if you don’t have a pressure drop between the air filter and throttle body then most likely you’ve got all the air flow you need.
    On a side note, everything I’ve owned and still own is modified. Just know what you’re getting into and why you’re doing it. I modify all kinds of things but just have real expectations. If you like it and it doesn’t hurt anything, then mod away and have fun. If you expected something different then probably just put it back to factory. I’m a huge fan of factory air boxes and filters on newer cars. Keep sensors clean and keep the dirt out, factory is best. Just pull the intake boot at the T body after a few thousand miles and see if excess crud is accumulating on the lip of the throttle. I see it all the time.
    markram likes this.
