Lost power on all gauges and A/C
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zorro, Jan 25, 2009.
  1. Jan 25, 2009 at 12:08 PM
    Zorro
    Zorro [OP] Member
    Florida
    SR5, 4X4
    EXO cage Manual Hub conversion 35" Swampers 4" Pro Comp lift
    Need some help!!
    After rearanging some wires in the kick panels LH and RH side, lost power on the gauges and dashboard lights plus the A/C quit. Everything else works. NO short in the wires that I can see.
    All my fuses are ok.
    Clock ok.
    Lights ok.
    The truck will start and drives ok.
    Any ideas?
    Zorro out
  2. Jan 25, 2009 at 5:59 PM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    definitely sounds like a fuse. did you check both fuse boxes?
  3. Jan 25, 2009 at 6:18 PM
    foxracinfor20
    foxracinfor20 Well-Known Member
    doug
    easton md
    05 prerunner lifted
    sway away 2.5 coilovers sway away race runner rear shocks pioneer avic d3 2 7 in monitors in headrest dvd memphis 10" sub memphis amp trd intake urd catback with magnaflow procomp wheels 33/12.50/17 angel eye projector halo headlights altezza tailights with led bulbs big blue balls hanging total chaos ucas cover king neoprene seat covers 7 led projector foglight
    i think the fuse for the guages on the 1st gen is under the hood
  4. Jan 25, 2009 at 8:11 PM
    Zorro
    Zorro [OP] Member
    Florida
    SR5, 4X4
    Guys,
    I did check both of the fuse boxes. No fuses are blown. What throws me off, is what does the A/C have to do with the dashboard gauges and light indicators.
  5. Jan 25, 2009 at 8:16 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    thats what makes it seem like a fuse...a lot of those things are tied together in the fuse blocks...
    i know i lost my headlights one time when i shorted my truck via the light in the ashtray :confused:
    and on one of my patrol cars...i lost my ac/turn signals on a fuse
  6. Jan 25, 2009 at 8:35 PM
    Zorro
    Zorro [OP] Member
    Florida
    SR5, 4X4
    Ok. I'll check one more time but I didn't find any fuses that were blown. Lets see what happens.
    Thanks,
    Zorro out
  7. Jan 25, 2009 at 8:39 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    i just checked out the FSMs on our trucks...ac and gauges arent on teh same fuse
    if your gauges are out...check your taillights
  8. Jan 25, 2009 at 8:39 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    I have a Haynes with the wiring diagrams for 1st gens but I'm not at home. Gimme a yell tomorrow afternoon if you don't figure it out before.
  9. Jan 25, 2009 at 8:41 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
  10. Jan 25, 2009 at 9:12 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    I would need more info on what's not working but the common power feed for the 10amp tail light fuse and the 10amp A/C fuse is 120amp Alt fuse.
  11. Jan 26, 2009 at 6:13 AM
    Zorro
    Zorro [OP] Member
    Florida
    SR5, 4X4
    Update:
    Well ALL the fuses are ok.
    I'll try to explain better:
    What doesn't work:
    -GAUGES: Tachometer, Speedometer, Fuel, Water Temp, and odometer.
    -Lights in the dash: Airbag, Check Engine, Cruise Control, parking brake, High beam, Blinker indicators, none of those indicators work at any time not even when cranking.
    -No A/C funtions work
    What does work:
    - Ilimination light of dashboard with deamer, Radio, Hazar lights, Head lights, Blinkers, Tail lights, Stop lights, power windows, electric mirrors.
    I can crank the truck with no problem and can drive around. 5 speed trans so no problem there.
    Hope this helps.
    Zorro out
  12. Jan 26, 2009 at 6:33 AM
    Ry1984
    so the fuses are all good...how bout the relays? all i can think of from this..
  13. Jan 26, 2009 at 9:11 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    There are a lot of key junction connectors and other wiring in the kick panels. Odds are you screwed up something with your 'rearranging' ...
  14. Jan 26, 2009 at 10:50 AM
    Zorro
    Zorro [OP] Member
    Florida
    SR5, 4X4
    Guys,
    Thanks for all the input, the zorromobile is fixed.
    I spoke with a friend that used to have a shop. Explained the symptoms and said he had a similar problem with a 4Runner a few years ago. The problem was the transmission relay that is in the RH side kick pannel. Purcahsed a new one and problem fixed.
    This happens when you start changing *&*^# around because of the mods.
    Zorro out
  15. Jan 26, 2009 at 1:53 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    good to know you got it fixed...my next guess wouldve been the relays but i dont know shit about whats tied into which so i wouldnt have been much help
