Lost power to engine on expressway, plz help! (VIDEO OF IT HAPPENING)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IcePlant, Dec 15, 2022.
  1. Dec 15, 2022 at 3:28 PM
    IcePlant
    IcePlant [OP] Well-Known Member
    Vince
    2017 BLACK TACOMA TRD SPORT DCLB 4X4
    -King 3" Lift -Leitner ACS Forged Bed Rack -TRD Pro Stainless Steel Cat Back Exhaust -TRex/ZRoadz Light Bar Grille
    I need help diagnosing what happened please! Thanks in advance.
    I was driving on the expressway and I lost power to the engine and couldn't accelerate, engine seemed to still be idling.. I had to coast over to the shoulder. Check engine light (orange) flashing and trac off light.
    I shut off the engine and restarted the truck and the lights were cleared. I went home and scanned it but no codes were stored. I was 5 miles from home and it ran fine.
    I've noticed these last couple weeks a very short rough idle that lasts for a few seconds as I'm about to park after driving somewhere.
    I'm at 111k miles and I replaced the spark plugs myself at 60k miles about 2 years ago.
    (May be irrelevant but I noticed my ignition coils were burnt because the factory didn't torque down 2 of the 6 original spark plugs. I made a thread on it at the time > Spark plug came loose from factory? | Tacoma World <)
    I am definitely going to replace the spark plugs and coils ASAP!
    Is there anything else that I should be looking at checking or replacing?
    Thanks!
  2. Dec 15, 2022 at 3:30 PM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Maybe it's the CPS (crank position sensor). It's a known fault that will randomly throw the truck into limp mode
  3. Dec 15, 2022 at 3:30 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Throttle body is my educated guess
    IcePlant[OP] likes this.
  4. Dec 15, 2022 at 3:32 PM
    IcePlant
    Vince
    what do you mean by that, just needs a visual inspection or cleaning?
  5. Dec 15, 2022 at 3:32 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Is your truck in the fuel pump recall range?
    Borracho Loco likes this.
  6. Dec 15, 2022 at 3:33 PM
    IcePlant
    Vince
    Noted! thank you - I'll keep this thread updated..
  7. Dec 15, 2022 at 3:33 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    A sudden loss of power while driving USUALLY (I could be wrong) points to a faulty fuel pump of clogged fuel filter. The clogged filter would explain the rough idling.
  8. Dec 15, 2022 at 3:34 PM
    TexasWhiteIce
    Texas
    I would clean it first and then go from there. I don’t think this is limp mode.
    IcePlant[QUOTED][OP] likes this.
  9. Dec 15, 2022 at 3:34 PM
    IcePlant
    Vince
    I'll have to check, gonna look now..
    I was actually thinking about replacing the fuel filter too. I think I'm overdue at 111k miles..
  10. Dec 15, 2022 at 3:35 PM
    IcePlant
    Vince
    thank you! fuel filter was definitely on my mind but I forgot to write that in the original post.
  11. Dec 15, 2022 at 3:38 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Dont they have a fuel sock after a certain year model?
  12. Dec 15, 2022 at 3:39 PM
    IcePlant
    Vince
    I just checked with my VIN on Toyota.com/Recall and it said "[​IMG] There are no open Safety Recalls or Service Campaigns for this vehicle."
    I'm leaning towards my fuel filter now..
  13. Dec 15, 2022 at 3:43 PM
    Borracho Loco
    DFW, Texas
    It's part of the pump.
  14. Dec 15, 2022 at 4:17 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i think the only fuel filter is integrated into the fuel pump. but this sounds like a bad crankshaft position sensor.
    shakerhood, wilcam47 and IcePlant[OP] like this.
  15. Dec 15, 2022 at 4:25 PM
    erok81
    erok81 Well-Known Member
    Imposter
    My money is on this. OP google CPS symptoms Tacoma and you’ll find results exactly like you have here.
    It was fairly common back in 16-17 that I carry a spare one in my glove box.
    Highly doubt it’s a fuel filter or a dirty TB. Clogs don’t usually completely clear when you cycle the engine. Electrical problem do however.
    shakerhood, Raylo, Phlogiston and 3 others like this.
  16. Dec 15, 2022 at 6:06 PM
    IcePlant
    Vince
    thank you. It makes sense. I didn't know the fuel filter was apart of the fuel pump assembly... I thought it was a quick swap out... I'll definitely order a new Crankshaft position sensor!
    thank you! I just bought one online and picking it up from a local dealer, hopefully tomorrow. $115 with tax..
    ENGINE CRANKSHAFT POSITION SENSOR
    $106.45
    Part# 9091905098
    shakerhood and erok81[QUOTED] like this.
  17. Dec 15, 2022 at 6:32 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    If you still have the issue after you have replaced the CPS it could be the ACIS. The cheap plastic shaft on the assembly breaks and when ACIS is activated the truck will go into limp mode. There are multiple posts about this you can search for more information.
  18. Dec 15, 2022 at 6:37 PM
    Little Lion
    Little Lion Well-Known Member
    2018 Barcelonian Sport MT
    bad fuel as well can run things amuck till its out the system. i thought something was deeply wrong with my last car but it was just a bad tank of gas.
  19. Dec 15, 2022 at 7:28 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    tacomas are very sensitive to bad gas
  20. Dec 16, 2022 at 4:50 AM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Great....just like my wife.
