Lost power
Discussion in '1st Gen. Tacomas (1995-2004)' started by OFTdrillerman, Aug 1, 2020.
  1. Aug 1, 2020 at 4:48 PM
    OFTdrillerman
    OFTdrillerman [OP] Well-Known Member
    2004 Lunar mist TRD Tacoma 5spd
    3" lift, K&N Cold air intake
    I have an 04 TRD with the V6 and a 5 speed. The truck seems to loose power and almost bog down at wide open throttle. You can let off the throttle to around 3/4s or half and can notice a improvement in acceleration. I’ve changed the fuel filter recently with no real improvement. Looking for suggestions. The truck has 147,000 miles.
  2. Aug 1, 2020 at 4:50 PM
    joshuajayg
    joshuajayg Well-Known Member
    Moab
    2020 TRD Off-Road MT
    Check engine light? Look for codes via OBD2 port?
  3. Aug 1, 2020 at 4:53 PM
    OFTdrillerman
    Forgot to mention, no check engine light. Will it have a code with no check engine light?
  4. Aug 1, 2020 at 5:04 PM
    tcjacado
    tcjacado Well-Known Member
    Oxygen sensors, catalytic converters, maf.
    Have all of these been determined to be good?
  5. Aug 1, 2020 at 5:08 PM
    OFTdrillerman
    Wouldn’t those cause a check engine light?
    tcjacado[QUOTED] likes this.
  6. Aug 1, 2020 at 5:10 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Dry rotted vacuum lines, maybe
    OFTdrillerman[OP] likes this.
  7. Aug 1, 2020 at 5:11 PM
    tcjacado
    Typically, yes. But sometimes no.
    Any alternator issues on it
  8. Aug 1, 2020 at 5:12 PM
    OFTdrillerman
    No alternator issues.
    tcjacado likes this.
  9. Aug 1, 2020 at 5:13 PM
    tcjacado
    Fuel pump?
  10. Aug 1, 2020 at 5:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    A converter (or even a muffler) that is in the process of clogging through interior decay can clog the exhaust stream and deteriorate high load performance quickly.
    Sometimes tapping on those will cause a rattle that gives you a hint.
    If it is one of those the condition will worsen until it won't run at all. Could be gradual, could be sudden.
  11. Aug 1, 2020 at 5:14 PM
    OFTdrillerman
    No issues cranking or idling, no missing or hiccups
  12. Aug 1, 2020 at 5:15 PM
    tcjacado
    Except..... loss of power at high rpm, correct?
  13. Aug 1, 2020 at 5:21 PM
    OFTdrillerman
  14. Aug 1, 2020 at 5:23 PM
    joshuajayg
    Moab
    You can have codes with no check engine light. Worth checking.
  15. Aug 1, 2020 at 5:23 PM
    OFTdrillerman
    Only at full throttle. If you only give it around 3/4 throttle it will accelerate like it should just seems to bog down when at full throttle.
  16. Aug 1, 2020 at 5:24 PM
    OFTdrillerman
    Will have it checked for codes on Monday
  17. Aug 1, 2020 at 5:24 PM
    tcjacado
  18. Aug 1, 2020 at 5:44 PM
    OFTdrillerman
  19. Aug 1, 2020 at 5:55 PM
    joshuajayg
    Moab
    My first two guesses are you throttle position sensor is faulty and is giving the wrong signal at peddle full down or you don't have sufficient fuel pressure.
    Best of luck.
  20. Aug 1, 2020 at 6:00 PM
    OFTdrillerman
    Thanks
