lost the HVAC blower on my 2009 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, May 11, 2025.
  1. May 11, 2025 at 6:53 AM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    For years, the HVAC fan speed control in my 2009 Tacoma has been squirrely. Speeds 1 and 2 were lower than they originally were when the truck was new. Sometimes, I'd have to use speed 3 to get anything at all.
    Yesterday, the blower stopped working altogether, even on speed 4.
    I ordered a blower resistor. In the meantime, what is the blower fuse labeled as (it's not obvious), and how many amps is it?
    Also, there's some confusion as to whether I'll need a new connector. The connector I have looks fine, and there are no signs of charring or corrosion. Will the factory connector work with the new resistor, which I believe will be an updated design?
    If I do need a new connector, will it need to be spliced into an existing wiring harness?
    Thanks for any help.
  2. May 11, 2025 at 7:03 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  3. May 11, 2025 at 10:45 AM
    Plasmech
    Thanks.
    This is extremely helpful.
    So I looked for the 10-amp IG1 No. 2 fuse in the under-hood fuse block for longer than I want to admit, but could not find it.
    Any clues as to where it might be hiding?
    ETA:
    Found it in the in-cabin block. I'm not near the truck now, but will check it. I reckon if IG1 No 2 were blown, though, there would be other weird $hit going on.
  4. May 12, 2025 at 6:38 PM
    Plasmech
    So this is interesting...
    Tonight, just for the heck of it, I plugged the wiring harness back into the resistor and tried the blower. It magically works again. All 4 speeds, like new.
    I then tried wiggling both the resistor harness and the blower harness to see if the blower would cut out. It did not. Fine.
    Wonder what happened?
    Am I good now?
  5. May 12, 2025 at 6:49 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^This must be what owning a GM vehicle is like all the time. :laugh: Instead you only have to deal with a GM-supplied HVAC system in a truck 50% built by GM.
    Dead spot in the blower motor perhaps?
    The resistor connector didn't change with the P/N roll. The new Denso resistor is plug & play. (I had a 2010 access cab and replaced both the resistor and blower motor, the latter due to chirping.)
  6. May 12, 2025 at 6:55 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You may want to check your blower switch for burnt pins.
    Plasmech[QUOTED][OP] likes this.
  7. May 12, 2025 at 7:08 PM
    Plasmech
    Wait, my 2009 has a GM HVAC system?
    Sorry, that went over my head.
  8. May 12, 2025 at 7:11 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^The HVAC system supplier was Delphi, a division of GM. Your truck was built in facility 50% owned by GM, with UAW unionized labor (hence the door jamb label "New United Motor Manufacturing..." instead of "Toyota Motor Manufacturing..."). The plant also produced the Pontiac Vibe and Toyota Matrix, both of which use the same cabin filter as your truck, not a coincidence.
  9. May 12, 2025 at 7:18 PM
    Plasmech
    Damn. Never knew that.
    So I’ve been drivng a ‘Murican truck around for 16 years while thumping my chest to the beat of Asian reliability?
    3JOH22A[QUOTED] likes this.
  10. May 12, 2025 at 7:21 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Yes the truck had some 76% 'Murican content, assembled by Commiefornia workers :p:oldglory:
  11. May 12, 2025 at 7:23 PM
    Plasmech
    Is the “new” Mexican plant that builds the Gen 4 a better plant?
  12. May 12, 2025 at 7:29 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^:notsure: I don't think any of us has public data on each plant's quality metrics. However, Toyota no longer had GM-supplied systems after GM's bankruptcy in 2010.
  13. May 14, 2025 at 5:19 AM
    Plasmech
    The blower stopped working again this morning. I gave it a hit with the 'ol fist, and it begrudgingly started up. I guess it's the blower itself. Ordered one this morning.
    3JOH22A and Dm93 like this.
  14. May 14, 2025 at 7:17 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Probably a dead spot on the Vietnamese GM blower then.
  15. May 14, 2025 at 7:31 AM
    Plasmech
    Gawd-damned Viet-nahms!
  16. May 14, 2025 at 11:43 AM
    Rougarou680
    Rougarou680 Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    Same thing happened in my daughter's 2006. It was the blower also.
