Lost upper transmission dipstick bolt anyone know the size?
Discussion in '1st Gen. Tacomas (1995-2004)' started by agalloch07, Dec 6, 2019.
  1. Dec 6, 2019 at 12:06 PM
    agalloch07
    agalloch07 [OP] Well-Known Member
    I just got done doing my transmission fluid change on my 2002 2.7 4wd Tacoma. I tried to remove the dipstick tube to make it easier and when putting it back on i lost the upper bolt that threads into the head. It has a 12mm head on it not sure what sixe the threads are does anyone know?
  2. Dec 6, 2019 at 1:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof, that bolt is a pain in the ass to get into place due to the dipstick tube wanting to "twist" as you put it into the drain pan.
    Any chance it just fell and it's sitting on your lower control arm or subframe?
    I dropped it like 5-6 times before I finally got it threaded on; scraped up my arm in the process.
  3. Dec 6, 2019 at 1:21 PM
    agalloch07
    I was trying to thread it in with a deep socket on a 6" extension and it somehow slipped and i never heard it hit the ground but i cant find it sitting anywhere on the truck either i think it's in another dimension now.
    Wyoming09 likes this.
  4. Dec 6, 2019 at 2:13 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    just a guess but if it's 12mm head it might be M10 bolt
  5. Dec 6, 2019 at 2:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just fish around; like I said mine fell and landed on the lower control arm once, on the skid plate, and a few other places.
    It only hit the ground when I felt around with my hand and accidently pushed it over.
    By the way, tag or quote someone if you're wanting to notify someone of a reply or something.
  6. Dec 6, 2019 at 2:41 PM
    Wulf
    rock raisin
    LCA, skid plate, steering rack, front diff, front sub frame....
  7. Dec 6, 2019 at 2:48 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Almost every bolt on the truck is either M8x1.25 or M6x1.0.
    koco, Wyoming09 and 12TRDTacoma like this.
  8. Dec 6, 2019 at 2:49 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This.
  9. Dec 6, 2019 at 3:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Could also fall onto the steering rack, front diff, sub frame, or the skid plate as well.
  10. Dec 6, 2019 at 3:47 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    M8x1.25 I would guess length to be 20 to 25 mm
    So nice to have a bolt bin and not worry about all the bolts and nuts I drop
  11. Dec 6, 2019 at 3:54 PM
    agalloch07
    Thanks i will try a M8x1.25 i doubt i will ever find the one i lost and since the trucks covered in wool wax and bar and chain oil i dont feel like digging around for it.
  12. Dec 6, 2019 at 3:55 PM
    Wulf
    rock raisin
    Don't worry you'll find it after you put the new one in
    JC15Taco and Wyoming09 like this.
  13. Jun 5, 2025 at 2:28 AM
    HeBuysLotsOfToyotas
    HeBuysLotsOfToyotas New Member
    Dan
    1972 Corolla, 1991 MR2, 1992 Landcruiser, 1992 Pickup Club Cab, 1996 RAV4, 2003 Tacoma Prerunner, 2003 Sequoia, 2003 Land Cruiser 100 Series,,2004 Tacoma TRD 4WD, ,2007&2014 Prius,
    Well for the benefit of anyone looking for information on the 1st gen Tacoma oil filler tube bracket bolt here it is:
    2003 Tacoma Prerunner V3.4 access cab,
    transmission filler tube bracket bolt 91651-40816
    replaced by Replaced by 90080-11229
    Info from link below:
    https://toyota-usa.epc-data.com/tacoma/vzn195l/3282/chassis/3503/?full
    Now it turns out that when I tried to remove this bolt the head broke off as the shank had seized. But I still had part of the bolt & washer. The wrench size for the head is M12. The bolt is actually an M7 (not an m8 as claimed above).
    The spec is M7-1-13. Not precisley sure of length but its close to 13 mm. I will measure it when I receive it and edit this post.
    Here is the bolt with some images on the the amayama website.
    https://www.amayama.com/en/part/toyota/9165140816
  14. Jun 5, 2025 at 4:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    Now THAT is some follow up! Thread went silent in 12/19, OP comes back with wrap up answer 6/25, 5 1/2 yrs later.
    Amazing! :eek::thumbsup:
