Lost!
Discussion in 'Wheels & Tires' started by jmal10, Sep 8, 2018.
  1. Sep 8, 2018 at 9:24 PM
    jmal10
    jmal10 [OP] New Member
    2014 PreRunner TRD Sport
    Ok, I’ve been trying to read through and figure out what it is I need and I’m all kinds of lost in the information. I have a 2” leveling kit on my ‘14 TRD sport.
    The wheels I’m looking at are 17x8 with a 0 mm offset and 4.5” backspacing. I want to run 265/70/17.
    Another option is 17x9 with a 0 mm offset and 5” BS. Same tire size.
    I will be getting a 17x8 or 9 wheel, so what do I need to do to run that tire size without any issues?
    Will these work without any issues? And how much will the stick out as I don’t want them to stick out drastically. I know this is a lot of questions, but I don’t want to be stuck with wheels that don’t work.
  2. Sep 9, 2018 at 11:16 AM
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    The 9" wide wheel will stick out 0.5" further than the 8". On my '08 and '17 the 8" wide wheels with 4.5" backspacing were about even with the fender flare. A 9" wide wheel is probably too wide for a 265mm wide tire. Most manufacturers recommend a max width of 8.5"
