lots of bump steer 96 2rz 2wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeffz0rz, Jan 12, 2012.
  1. Jan 12, 2012 at 4:41 PM
    jeffz0rz
    jeffz0rz [OP] Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Single cab non prerunner, with downey upper, lower and coilovers on 31's. Have had it aligned and still get really bad bump steer. Anyone else had or have a similar situation? Not sure how to remedy it.
  2. Jan 12, 2012 at 4:42 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    How are your steering rack bushings? does the rack move side to side when you turn the wheel back and forth?
  3. Jan 12, 2012 at 6:25 PM
    jeffz0rz
    san diego
    Excellent question....I don't know.
  4. Jan 12, 2012 at 7:23 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    pardon my ignorance, but what is bump steer?
  5. Jan 12, 2012 at 9:19 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
  6. Jan 13, 2012 at 9:44 AM
    TacoMX
    Jonathan
    Deltona, Florida
  7. Jan 13, 2012 at 12:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yes on both counts lol
    the op is not experiencing true bump steer since he doesn't have a long travel suspension kit designed by a retarded monkey on his truck (^see above for example of that). the geometry is correct on the stock suspension.
    what is probably happening is the steering rack is loose in its mounts because of worn bushings making it feel like bump steer.
  8. Jan 13, 2012 at 12:23 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    On my truck I hit a hole so hard that it caused my steering rack to jump a tooth. Didn't realize it at first, did the alignment myself just to get things close enough, and found that the tie rod on one side had a lot more threads exposed compared to the other side.
    Bumpsteer was insane until I corrected it. Somehow the rack still worked fine, so I popped the steering shaft from the rack, re-centered the rack, reconnected the shaft with the everything centered, and realigned the truck. Took care of that problem.
  9. Jan 13, 2012 at 6:12 PM
    jeffz0rz
    san diego
    I'm not running stock suspension. Its a downey "mid travel " set up. What's this about your rack jumping a tooth? I checked out my rack bushings, and they seem tight and in good shape. Is it possible my wrack is leaking inside causing the steering to seem off?
  10. Jan 19, 2012 at 4:21 PM
    jeffz0rz
    san diego
    Is the shaft in the rack a one piece or two piece design? Just got an alignment, marked everything to see if things are coming loose, and nothing is budging. My tires are so badly toe in its insane. What is loose!?
