Lots of milky condensation in oil cap and filler neck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spaz10, Feb 20, 2010.
  1. Feb 20, 2010 at 8:16 PM
    spaz10
    spaz10 [OP] New Member
    Joe
    Lancaster
    TRD Sport
    I am finding a lot of yellowish milky condensation covering my filler cap and filler neck. Toyota says it's normal, but it seems like an awful lot for it to be normal. Does anyone have any ideas?
  2. Feb 20, 2010 at 8:24 PM
    wmflyfisher
    wmflyfisher Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    I just noticed this my last oil change so it makes me feel better that Toyota said it was normal. Maybe some others will chime in. I think I've heard in the past that it's condensation from the crankcase and normal. Hope it is!!
  3. Feb 20, 2010 at 8:24 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Are you using synthetic oil? I find that the synthetic oil makes it even worse..Cause I use Mobil 1 5W-30
    Do you take short trips to work each day?
    My 05 Tacoma 4.0 does the same thing and it makes allot of that yellowish stuff under my oil cap and even more in the winter
    It's condensation and can't burn off of the plastic oil filler neck and cap like it can on other metal engine parts witch get hotter
    Not a whole lot you can do about it
  4. Feb 20, 2010 at 8:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its normal. Lots of short trips, and cold weather cause this. Change the oil more frequently.
    tacopearl likes this.
  5. Feb 20, 2010 at 8:27 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    That is usually not a good sign, milky looking oil is a sign of water. Could be head gasket or something to that effect. Does it show up on the dip stick? If so i would definitely question there "normal" statement. Do you have a scan guage, if so i would monitor your engine temp daily, if temp continues to gradually increase over time you have a water leak somewhere.
  6. Feb 20, 2010 at 8:28 PM
    Vectorit
    Vectorit Well-Known Member
    Southern California
    TRD SR5
    King coil overs, Total Chaos uppers, Snugtop
    To be blunt, you have serious problems.
    Do not run the engine, since you are circulating coolant and will destroy the motor.
    Still under warranty? drag it to the stealer and have them fix it.
    No longer warrantied? drag it to the best mechanic you know, and be prepared for a big bill.
    Frothy, or milky oil is "not normal".
    Simple as that.
  7. Feb 20, 2010 at 8:30 PM
    chugchug
    chugchug Well-Known Member
    Will
    Frederick MD
    2012 Toyota Tundra
    I change my own oil for the first time since i bought the truck in Nov. It had a bunch of that crap in it so unbolted the filler neck and cleaned it out and put it back on.
    Timbuktu likes this.
  8. Feb 20, 2010 at 8:33 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    x2
    JDKred and Timbuktu like this.
  9. Feb 20, 2010 at 8:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hold off on the Doom and Gloom, folks. Condensation forms under the oil cap, as mentioned, it is platic. Short trips can cause water to get into the oil, as water is a by product of the cumbustion process, and if the engine isnt run long enough at operating temp, it cant burn this off. Thus the "Milky" colored oil under the cap. Knock the oil change interval down to 3K miles durring winter, or sooner if all you do are short trips, and it should go away. Also, maybe consider sending an oil sample to http://www.blackstone-labs.com/ to see how the engine is doing.
    Dirt likes this.
  10. Feb 20, 2010 at 8:34 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Apaz10, just liked mentioned up above my post by other members, it is probably just condensation. Could also be coolant, probably not but should check the dipstick.
    Here is a link on the same subject, review both threads. http://www.tacomaworld.com/forum/general-automotive/76088-help-oil-change.html#post1450847
  11. Feb 20, 2010 at 8:36 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    if it just on the cap your ok, like Chris said, just change oil more often. I get it from short file mile commutes, I suspect the extreme colds dont help either. I had oil tested and it was fine.
  12. Feb 20, 2010 at 8:36 PM
    jandrews
    '09 FourDubDee TRD OR
    No need to freak out yet. This isn't something huge.
    It's called "cold water sludge" and it comes from moisture condensing in the crankcase in cold weather, and trips in the truck too short to allow the moisture to boil off.
    Estimates vary, but the conventional wisdom is your engine needs to spend 20 minutes or so at operating temp to boil off condensed moisture completely.
    Take a long trip every 2 or 3 trips, or start giving the engine some time to warm up. Should at least decrease the problem.
  13. Feb 20, 2010 at 8:37 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Nobody said anything about milky oil. He is referring to the milky substance that collects on the underside of the filler cap due to the long, plastic filler tube being surrounded by cold air.
  14. Feb 20, 2010 at 8:38 PM
    dirthawker1313
    dirthawker1313 Well-Known Member
    x2
    my wifes 99 tahoe had "condensation" on her oil cap and filler neck. it turned out to be an intake manifold gasket that was leaking coolant in to the motor. its not normal to have "condensation" in the motor. once i fixed the leak the "condensation" went away.
  15. Feb 20, 2010 at 8:45 PM
    Vectorit
    Southern California
    TRD SR5
    Condensation, water, or coolant is not a "normal" situation to just shrug off. Water, and especially coolant will tear up crank case bearings super quick.
  16. Feb 20, 2010 at 8:48 PM
    jandrews
    Agreed, but this isn't from some mechanical defect in his engine. It's how he's using the vehicle, and it's essentially unavoidable with that type of use.
    There's a reason we always hear about engines doing their best at operating temp...it prevents this kind of stuff.
  17. Feb 20, 2010 at 8:51 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^^What Cris4x4 said. Also, I've read the condensation forms due to the plastic fill tube...perfectly normal with our trucks and nothing to worry about.
  18. Feb 20, 2010 at 8:56 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    :D sweet mother of mercy
    its a normal thing to have this under the cap. on Tacoma 4L V6 . filler neck is too long so it never heats up, synthetic makes it worse since engine runs cooler'
    4T3Underhill and Timbuktu like this.
  19. Feb 20, 2010 at 9:09 PM
    Vectorit
    Southern California
    TRD SR5
    hmmm, OK, well if that's what "the factory" tells ya then it must be OK right?
    Long oil fill tube? you are kidding right?
    To me I don't see this as something worthy of debate.
    Water/condensation + oil = damage.
    The OP should have everything checked out none the less.
  20. Feb 20, 2010 at 9:09 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    Wait stop what your doing!! this is a tsb and recall....NOT ...its no big deal ...take the tacoma on a road trip and the condensation will go away:D
