Lots of milky condensation in oil cap and filler neck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spaz10, Feb 20, 2010.
  1. Feb 20, 2014 at 6:03 AM
    #141
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    Just a thought. What would happen if you somehow wrapped the filler tube with some kind of insulation? Would that stop the condensation?...
  2. Feb 20, 2014 at 6:08 AM
    #142
    welterbf123
    Columbus, OH
    2017 TRD Off Road
    Water boils at 212*F at sea level...
  3. Feb 20, 2014 at 6:11 AM
    #143
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    More redline. Less issues. Much fun.
  4. Feb 20, 2014 at 6:19 AM
    #144
    welterbf123
    Columbus, OH
    2017 TRD Off Road
    This is a great write-up. My son, however, had this bubbling issue on his '98 4Runner and after replacing the head gasket, the bubbling went away. I can only surmise that this is not always a sign of a cracked head or cylinder wall. It all depends upon what part of the head gasket is leaking.
  5. Feb 20, 2014 at 6:25 AM
    #145
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    '14 SR5 AC 4x4 6Spd
    This is not a problem unless the oil in your pan looks the same way. If it bothers you suck some oil out of the pan and send it off to blackstone labs to get analyzed. One of the many measurements they have is for water % in the oil.
    The plastic neck/cap just doesn't get hot enough to cook the condensation off, not a big deal.
    Edit: Not a big deal if you drive it regularly. If you park it for months at a time then you might need to change the oil based on time in the engine instead of miles driven.
  6. Feb 20, 2014 at 7:04 AM
    #146
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    My question or concern would be where else is that milky crap building up? Normal or not I would not want it. If its moisture than it can burn off if you get the engine up to temp. Drive a little more or let it run longer.
    If you have no leaks and this is "normal" what kind of oil are you running and I would run some sort of engine cleaner through it to clean where all that oil goes to just try and cut it back or get it cleaned out.
    Look into BG 109 Compression Restore, google it and just read some of the results of this product.
  7. Feb 20, 2014 at 7:17 AM
    #147
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I don't think there is anywhere else that stays cool enough for that build up.
    I changed my oil not to long ago, and had a little build up on the cap. Partly because I don't drive as much or as far as I used to. My oil looked fine coming out. It's really no issue. No one has had any engine problems with this happening, and I'd be willing to bet that everyone will continue to not have an issue.
  8. Feb 20, 2014 at 7:35 AM
    #148
    Navar
    Corona CA
    Just offering an opinion and help.
  9. Feb 20, 2014 at 7:45 AM
    #149
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    It's all good. People just seem to be making a big deal about this, when its not.
    Coolant in your oil? = problem.
    Just some build up on your cap? = no problem.
  10. Jan 7, 2015 at 6:24 PM
    #150
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    I've noticed the milky substance on the filler cap today. I switched to SuperTech Synthetic oil last time I did an oil change.
    I just a small USB camera down the filler neck to check for any sludge but it's clean.
    I am sucking this up to short drives in cold weather, the oil that drained looked normal.
    I will report back after a 300 mile round trip tomorrow.
    *edit: no water came out of the oil pan, coolant level is full and pressure
    tests fine. when I pulled the dipstick before dumping the oil, the oil was not milky.
  11. Dec 8, 2016 at 7:28 PM
    #151
    timbobzimbob
    timbobzimbob Well-Known Member
    Tim
    Ottawa, Ontario
    05 DCLB 4x4
    welcome to the family :thumbsup:
    surforegon likes this.
