Lots of Squeaking in my front end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eyesofdeath13F, Sep 1, 2011.
  1. Sep 1, 2011 at 6:49 PM
    Eyesofdeath13F
    Eyesofdeath13F [OP] New Member
    Jeremy
    Olympia, WA
    06 Tacoma TRD offroad
    6 inch fab-tec lift 36" BF Goodrich MT KN Cold Air Intake ARB Bump with Warren Winch
    Looking for advice on what could be causing all the squeaking in my front suspension. I have a 06 Tacoma double-cab with a 6 inch fabtec lift. It sounds as if the bushing need to be replaced as well as the haft shafts and shocks. Does anyone know where I can buy a replacement bushing kit? Do I need one from Fab-tec or will something else work? Any help would be greatly appreciated.
  2. Sep 1, 2011 at 6:52 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    are you using stock or aftermarket UCAs?
  3. Sep 1, 2011 at 6:53 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Welcome to TW
  4. Sep 1, 2011 at 7:06 PM
    Eyesofdeath13F
    Jeremy
    Olympia, WA
  5. Sep 1, 2011 at 7:08 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    upper control arms
  6. Sep 1, 2011 at 7:09 PM
    The_Hodge
    SC
    ^^this. if you dont know if they're stock or not, pics would help.
  7. Nov 18, 2013 at 9:25 AM
    BrandonDean
    BrandonDean Member
    I may have found the issue to the front end squeaking. (time will tell) When the hood is open and you bounce the truck you cant hear a thing the second i closed the hood the noise came right back. Couldn't find where anything was scratching until we looked at the hood latch. Paint was being scrapped off the bottom of the hook so my guess is that is was metal to metal noise from the front. After adding some lube i have not heard it in now 24hrs. Im sure when it dries again it will come right back so ill need to figure out a way to adjust it or see if toyota knows how to adjust the latch. Ill be back if it ends up not being the solution.
