Lots of warning lights on dash, no gauges or temp working, truck drives normal.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dirt McGirk, Aug 21, 2025.
  1. Aug 21, 2025 at 1:22 PM
    Dirt McGirk
    Dirt McGirk [OP] Well-Known Member
    Phoenix, AZ
    19 TRD OR 4X4
    Hello,
    wondering if anyone has had this come up.
    Started my truck right now with my remote start, ran for probably 15 min, I get in and press the brake for the takeover and I got a bunch of warning messages and basically every light on the dash.
    From what I can remember:
    Pre collision malfunction
    ABS
    Brake control start override malfunction (something like this)
    And maybe a couple other.
    Once I close all warning I get no reading on the gauges at all, but truck drives normal and isn’t in any limp mode. Turned off and on a few times and no change.
    Not sure if this potentially has to do with it being like 113 degrees right now, truck has been in the sun all day and maybe something got hot and needs to cool down, or maybe a voltage issue.
    I am home alone with my 6 month old and it’s way too hot to have him in the garage, so all I’ve done so far is pull into the garage and unhook the battery. Wife will be home in a couple hours and I will see if cooling down and unplugging the battery resets it, and will check battery voltage.
    wilcam47 likes this.
  2. Aug 21, 2025 at 1:41 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Did you install anything new recently?
  3. Aug 21, 2025 at 1:44 PM
    Dirt McGirk
    Phoenix, AZ
    19 TRD OR 4X4
    Negative. Nothing touches anytime recently.
  4. Aug 21, 2025 at 1:45 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Check the IG1 and IG2 fuses. Sounds like a main bus fuse failure.
    Dirt McGirk[OP] likes this.
  5. Aug 21, 2025 at 1:50 PM
    shaggy135
    How old is your battery?
  6. Aug 21, 2025 at 1:52 PM
    Dirt McGirk
    Phoenix, AZ
    19 TRD OR 4X4
    will do, thank you.
    3 years, so could absolutely be that.
  7. Aug 21, 2025 at 1:53 PM
    shaggy135
    That's what I'm guessing. I've also got a '19. I'm on my 3rd battery now. 3 years is about the limit down here in the heat.
  8. Aug 21, 2025 at 2:11 PM
    Dirt McGirk
    Phoenix, AZ
    19 TRD OR 4X4
    100% agree, I’m gonna grab a new battery when my wife gets home to start.
  9. Aug 21, 2025 at 2:13 PM
    shaggy135
    I saw that Autozone carries AGM ones now if that was something you are interested in. I've been wondering if they'll last any longer. Once I'm out of warranty, I'm going to try one.
  10. Aug 21, 2025 at 2:17 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I'd take a close look at the remote start too especially since it happened right after that.
  11. Aug 21, 2025 at 2:39 PM
    Dirt McGirk
    Phoenix, AZ
    19 TRD OR 4X4
    I am going to grab a standard lead acid interstate at Costco, I believe our alternators don’t out of enough voltage to charge an agm battery without some changes being made by a tune.
    it’s a possibility, it’s not the first thing but is on my list.
  12. Aug 21, 2025 at 2:48 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    What i do when getting battery at costco.
    take tools to change it
    Make sure they have correct battery.
    buy it, change it in the parking lot
    take the old one back in
    DONE!
  13. Aug 21, 2025 at 2:54 PM
    Dirt McGirk
    Phoenix, AZ
    19 TRD OR 4X4
    Just going to pull mine before I go, I’ll take the wife’s 4runner.
    itsnotatoy and kahanabob[QUOTED] like this.
  14. Aug 21, 2025 at 4:25 PM
    itsnotatoy
    itsnotatoy Well-Known Member
    Tom
    NW Valley AZ
    2023 Tacoma DCSB ICE CAP TRD Sport Premium & Tech Pkg
    You have to pick up an AC for the garage too! Gotta have AC in the Garage in PHX. 112 today!
  15. Aug 21, 2025 at 4:54 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Aside from the battery, the heat shouldn't affect your truck to make it behave like that. My truck is outside in the sun most of the day and it hasn't had that happen.
    While it doesn't hurt to replace an older battery before it totally craps out on you and leaves you stranded, remember that the battery was strong enough to start your truck and then it was running on the alternator, not the battery.
    check those fuses as mentioned above, not just a visual but a test.
    throwing parts at your truck before you know exactly what is wrong with it can get expensive.
    itsnotatoy likes this.
  16. Aug 21, 2025 at 6:24 PM
    Dirt McGirk
    Phoenix, AZ
    19 TRD OR 4X4
    Replaced the battery and I’m up and running normal again! Not sure if it was the battery itself or just resetting the ecu by having it disconnected for a couple hours but I’m not going to question it.
    Thanks everyone for the replies and advice!
    I know, I’ve been looking at doing a mini split but never pull the trigger.
    I agree with you, I decided I needed a battery regardless but I would have started diagnosing after.
    Chew and Phlogiston[QUOTED] like this.
  17. Aug 26, 2025 at 3:28 PM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    My lane assist doest work when it’s been outside on very hot day. Once the cab cools down it starts working. My anytime backup camera with front cam also quits working, annoying.
    I need new battery too. Oh and my 19 sits mostly in a cool 82degree garage when not being driven.
  18. Aug 26, 2025 at 3:54 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    WMart NeverStart ( everstart ) is as good as anything and it will be about $30 cheaper... or more.
    Any chance you were caught in that storm last night and something got dusty?....
    And god-forbid you got some critter chewing on some wires.
    Anywho let us know who/what/where/when/why ..
