Loud bang switching to 4 wheel drive
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xXDeadfishXx, Dec 11, 2022.
  1. Dec 11, 2022 at 7:32 AM
    xXDeadfishXx
    xXDeadfishXx [OP] Member
    Ashley
    2019 Tacoma Off Road
    BDS Suspension 6inch lift 33s with 18inch wheel
    I recently used/switch on my 4wheel drive, and I heard a loud bang sound and my truck jerked. Is that normal?
    I was on an uphill gravel road, going approximately 15mph, made a small turn before I switch onto 4wheel drive.
  2. Dec 11, 2022 at 7:35 AM
    Bishop84
    Bishop84 Well-Known Member
    It happens from time to time, not a big deal, just make sure to use it while coasting in a straight line and it usually won't clunk.
    Going uphill it had a lot of load on it and made it more difficult to engage.
  3. Dec 11, 2022 at 7:40 AM
    OuchIDied
    OuchIDied Well-Known Member
    2021 Silver Sky Tacoma Off-Road
    I like to switch to 4HI with my foot off the throttle. Coasting along in a straight line makes for an easier switch.
    Irons, oconnor, Chew and 1 other person like this.
  4. Dec 11, 2022 at 7:54 AM
    xXDeadfishXx
    Ashley
    Thanks folks!
    Ahh, makes sense, the uphill made a difference, and I was also throttling while switching to 4wheel drive.
    musicisevil likes this.
  5. Dec 11, 2022 at 8:30 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Sounds like you’ve got it. You also want to have the wheels straight and not be in the middle of a turn when engaging. With the conditions others have described already (slack in the drive line), the 3rd gens will engage 4wd almost silently
    xXDeadfishXx[OP] likes this.
  6. Dec 11, 2022 at 10:36 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    as others have already said- it's engaging with a load on the driveline.
    When I am offroad, I generally drive with the mindset, that I want X (4W high, low, locker, etc) feature on before I need it. Not talking down to you, but try to keep this in mind, and it will help not only with the clunk, but will help you get through tough areas better.
  7. Dec 11, 2022 at 10:45 AM
    Friar_Fresh
    Friar_Fresh Well-Known Member
    Durango, CO
    MT TRD OR, Ultimate Tourer
    I drive a manual taco, typically if I’m moving when I want to turn on/off (typically off as the road to my house needs 4x4, but once I get to the road I don’t need it) I will put it in neutral and rarely if ever hear the clunk. Now when putting it in 4Lo, I usually get an erection cause that clunk means is time to give something the business
  8. Dec 11, 2022 at 11:05 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My 2001 tundra did the same when pushing the 4wd button when the truck was under power. My 2020 tacoma 4wd system works slicker than goose poop on a wet lawn. No nothing. it just clicks in or out of 4wd flawlessly. Doesn't matter whether under power or not. I don't even know when it engages, or disengages except for the green 4wd display on the dash.
  9. Dec 11, 2022 at 3:14 PM
    xXDeadfishXx
    Ashley
    yeah, same here, I wasn’t aware if it was engaged or not. It was an expected off road, wasn’t planing to go that way, until I saw the steep gravel road. I’m just worried if anything is damaged. I tried to turn on and off while driving local, didn’t experience any issues. ‍♀️
  10. Dec 11, 2022 at 6:11 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    It’s fine, just try to avoid doing that.
    Now, sometimes we don’t always have a crystal ball and have to make the switch under power, just try to reduce it.
  11. Dec 11, 2022 at 9:38 PM
    hafjell
    hafjell Well-Known Member
    Idaho
    2023 TRD OR MT
    Put it in neutral, release the clutch, and let it glide before flipping into or out of 4High? Is there a speed limit to the procedure?
  12. Dec 11, 2022 at 9:57 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    62mph is the limit to engage. Don't believe there's a limit to disengage.
  13. Dec 11, 2022 at 10:02 PM
    hafjell
    Idaho
    2023 TRD OR MT
    Thank you. Is there a speed limit for 4High?
  14. Dec 11, 2022 at 10:17 PM
    Friar_Fresh
    Durango, CO
    It’s before I give any gas, preferably before turning onto the main road (at a stop/rolling stop)
  15. Dec 11, 2022 at 10:21 PM
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Sounds like you had a slight delta in the wheel speed between the front and rear axle...up hill on gravel there might have been a tiny bit of slip.
  16. Dec 12, 2022 at 8:32 AM
    TacoMamba35
    PNW
    Max speed in 4HI same as 2WD.
    hafjell[QUOTED] likes this.
  17. Dec 12, 2022 at 9:02 AM
    hafjell
    Idaho
    2023 TRD OR MT
    Thank you. Helpful.
