Quick Links:Bolt Size to Use with Puller, to Remove Crankshaft Timing Sprocket on 3.4L V6 5VZ-FE?
Need help with temerature sensor 98 22re Transmission / Differential Slip, or Misfire?
What would be your next step for dealing with this brake booster/master cylinder issue?
Caliper pins grease or not?
Door locks
Loud banging noise from manual trans
Discussion in '1st Gen. Tacomas (1995-2004)' started by badham_dixon, Oct 24, 2023.
