Loud clank during hard braking & speed bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CruJones33, Jun 21, 2011.
  1. Jun 21, 2011 at 4:27 PM
    CruJones33
    CruJones33 [OP] Member
    Pretty loud metal clanking sound coming from under the truck during hard braking and speed bumps. Any idea's? (No tow hitch)
  2. Jun 21, 2011 at 5:12 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Front or rear? Have you recently done any mods?
  3. Jun 21, 2011 at 5:14 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    Someone swipe your spare tire and the little thingie is hanging from the cable and banging into things?
    Seriously though, maybe u-bolts loose in the rear?
  4. Jun 21, 2011 at 5:52 PM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    I had this, with the exact same symptoms you are describing. Way too loud to be the "brake pads floating".. not that every one has the same issue BUT.. mine ended up being the Lower Control Arm bolts were not tight enough. Had someone reverse, brake hard, drive forward , brake hard and voila.. saw the bolt head on the back side of the passenger side LCA pop up and down on the alignment cam. Fucking Wheel-works :bananadead:. Thanks for not checking the bolts after my last alignment.
