LOUD Clunk shifting into 4Hi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NAYo2002, Dec 10, 2009.
  1. Dec 10, 2009 at 9:41 PM
    NAYo2002
    NAYo2002 [OP] Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    Okay I sort of did something stupid by mistake. Now I'm just trying to see how big of a mistake it was and how I can fix it.
    This morning I was trying to make it into my garage in 2wd, my driveway is fairly steep and snow/ice covered. The Taco wasn’t climbing any farther and I was so close to being in the garage. Impatiently, I switch to 4Hi while I was still giving it gas to make it up the driveway.
    That's when I heard a really Loud Clunk. I really thought I broke something. Maybe I did. Do you guys happen to know what that Loud Clunk noise might be? I heard a clunk every now and then shifting from 2hi to 4hi but this time it was much louder.
    The 4wd indicator kept blinking for several seconds. I made it into the garage, and it was still blinking. So I decided to make sure it still works. I reversed out of the garage and finally the 4wd indicator stays on. I drove back up the driveway and everything seemed to be working fine.
    Later in the day, I put it in 4hi on an icy road to see everything was still functioning. 4wd comes on just fine and I don't notice any fluid leaking, grinding noises, etc. I switched it back and forth multiple times just to make sure.
    So the question is: should I be worried? And if so, what else should I check?
  2. Dec 10, 2009 at 9:50 PM
    dorkman
    dorkman Well-Known Member
    Your fine. You have an 09, the 4x4 is just breaking in, should shift in and out easier over time. Mine flashed more in the beginning and made a few clunks along the way.
  3. Dec 10, 2009 at 10:02 PM
    NAYo2002
    Great Falls, MT
    Does anyone know what that Loud Clunk noise might be? It's 100x louder than the clunk I hear every now and then while shifting to 4hi.
    I think it maybe been because I shifted into 4hi in high RPMs due to spinning back wheels. But, what component could've made that noise?
  4. Dec 10, 2009 at 10:04 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    if you were spinning while switching to 4x the clunk was the tcase and front driveshaft engaging as well as the front diff. I wouldnt do it if you value the truck. Only switch to 4x if your front wheels are going the same speed as the rear wheels.
    Ex. switching to 4x while moving is fine, but if your spinning in 2x the rear wheels are spinning faster than the front so when you switch to 4x the front components need to catch up... real bad idea...tough on the whole drive train
  5. Dec 10, 2009 at 10:06 PM
    NAYo2002
    Great Falls, MT
    Is there anything I should do, or just need to avoid doing it in the future?
    Could there be permanent damage and what would be signs of permanent damage?
    I'm new at this.
  6. Dec 10, 2009 at 10:09 PM
    dorkman
    What you said.
    And if so take it to the dealer, if it breaks that easy you should get a refund. Or at least take it in for warranty.
    But your fine, go to bed. You can sleep, everything is fine....Obama won the Nobel Peace prize, all is good and well.
  7. Dec 10, 2009 at 10:11 PM
    Yoytoda
    Roland
    completely stock
    Doesnt matter what brand of car it is. gears are gears. The design of the tcase is to engage the front drive shaft. The front drive shaft spins the same speed as the rear. if the rear is spinning and you shift into 4x the front has to catch up instantly...easily cause instant carnage...
  8. Dec 10, 2009 at 10:12 PM
    NAYo2002
    Great Falls, MT
    ha ha
  9. Dec 10, 2009 at 10:15 PM
    NAYo2002
    Great Falls, MT
    Well I guess I will just have to wait and see if things start acting funny.
  10. Dec 10, 2009 at 10:15 PM
    Yoytoda
    Roland
    completely stock
    DONT do it again...
    Breaks that easy??? its like smashing the gears with a sledge hammer. if it was on dry pavement youd be needing a front drive...
    "Obama wins the Heisman Trophy just for watching a single game!!!" cheezy anouncement voice
  11. Dec 10, 2009 at 10:56 PM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    hahahaa thats great!
  12. Dec 10, 2009 at 11:27 PM
    GTVAPSAMTIK
    GTVAPSAMTIK Well-Known Member
    SOHAIL
    Fort Carson, CO
    2010 TRD OFF-ROAD 4X4 Automatic
    EXTANG Tuff WeatherTech Liners Toyota Bed Mat Coverkind Seat Covers
    According to the manual you can switch into 4WD 2Hi as long as you are under 60MPH. You should be fine. Correct me if I am wrong anyone.
  13. Dec 10, 2009 at 11:29 PM
    Yoytoda
    Roland
    completely stock
    thats if the vehicle is moving 60mph(all 4 wheels). If the rear is spinning 60 mph and the front isnt moving thats bad news...the front wheels have to be moving the same speed as the rear so the gear speed is matched
  14. Dec 10, 2009 at 11:33 PM
    riggsjt
    riggsjt Well-Known Member
    Jake
    Meridian,MS
    11 FJ Cruiser
    That is correct, if the front and rear wheels are moving at 60 mph. this means all the gears are moving at the same speed just not messed together. if your back tires are spinning at 60 mph and your front tires are at a standstill you are trying to mess a gear spinning at 60 mph with a gear at a dead stop... this is a horrible idea.
  15. Dec 10, 2009 at 11:41 PM
    Yoytoda
    Roland
    completely stock
    Oh, well the OP was asking a serious question and your answer looked serious...
  16. Dec 10, 2009 at 11:47 PM
    Yoytoda
    Roland
    completely stock
    Id be pretty stressed about it, lol. id take it while its still under warranty. At least even if there is nothing wrong with it you can have a problem documented before the warranty is up so you have ammo if it fails in a few years...I threw a truck into 4x while spinning in mud once and twisted off the front driveshaft. It was ugly...
  17. Dec 11, 2009 at 3:43 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    As a rule of thumb I usually take my foot off the accelerator pedal momentarily and coast while switching into or out of 4wd. It eliminates the risk of the rear wheels spinning while engaging and removes the load from the system when disengaging, avoiding that other dreaded clunk.
    It isn't necessary, but certainly seems like it allows the system to engage/disengage easier.
  18. Dec 11, 2009 at 4:45 AM
    roddyrod72
    roddyrod72 Well-Known Member
    Greenville, KY
    '10 SR5 Regular Cab 4x4 5 sp manual
    DRL OEM Mod, OEM Cruise Mod, 3" Lift, painted OEM grill
    What about vehicles that have auto 4wd? Wouldn't this cause the same problem? If your rear wheels have no traction, it automatically engages the front driveshaft. My wife's trailblazer has it, but I'm scared to use it. haha. Especially in a GM product. I always use 4hi or low....not that automatic crap.
  19. Dec 11, 2009 at 5:19 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    +1, I do the same, make the change where there's no slipping or load on the driveline, and it'll go in/out no problem, no clunk.
  20. Dec 11, 2009 at 6:39 AM
    NAYo2002
    Great Falls, MT
    Should I just take it to the dealer and ask for an inspection? I have no visible or audible sign of damage so I'm not sure what to say to them. I don't really want to document that I did something stupid either just in case it might void the warrenty.
    Did you have to do anything to that truck?
