Loud CLUNK when going over speed bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoman10101, Jul 11, 2023.
  1. Aug 10, 2023 at 12:50 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Spare tire looks tight in video.
    Have you recently done anything to the truck...when did it start?
    My clunk was the receiver hitch/pin I had in the boxes side compartment.
    I never use the compartments or the hitch so I forgot about it.
  2. Aug 10, 2023 at 1:04 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    My clunk ended up being a loose attachment of the front sway bar to the spindle. Was super hard to diagnose since it had to be perfectly unloaded to allow any noticeable play. Found this after replacing the front body mounts by the radiator thinking that was the culprit...
  3. Aug 10, 2023 at 1:15 PM
    The Art Of Shredding
    The Art Of Shredding Member
    2017 TRD Off Road
    Yeah I took off spare tire and still has the noise. I noticed it about a month after I purchased it purchased it about 6 mths ago. It feels like it’s coming from both leaf springs. I’m nearly certain that’s where the noise is coming from. Maybe slightly worse on passenger side. I did fluid film the leaf packs and frame around 3 weeks after purchasing. Bushings look great. Almost like the leafs maybe shifting. ‍♂️ I’m gonna swing by Toyota dealership tomorrow and see what they say. Probably tell me it’s normal. It’s more just annoying when I off road.
  4. Aug 10, 2023 at 1:26 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I was thinking maybe springs or bushings too. Does the fluid film get dried out over time. Maybe they need some lube but if you think they're sliding around then your ubolts aren't tight enough. Probably shouldn't lube them yet.
    If you chock the wheels and toss the parking brake on, you can loosen the ubolts and straighten the springs.
    Plenty of videos out there.
  5. Aug 10, 2023 at 1:41 PM
    2017 TRD Off Road
    Yeah, I think I will give that a shot.
  6. Aug 27, 2023 at 5:57 PM
    Tacoman10101
    Tacoman10101 [OP] Well-Known Member
    So I finnaly found the issue and it was close to this, got someone to jump in the back of the bed causing the suspension to flex and followed the clunking sound.... Ended up being my stupid air bag system, the leaf spring guide was out of place and the u bolt was a little loose. Centered the guide, tightened up the u bolt so it doesn't shift over and the annoying clunk is finally gone!
    winkel and The Art Of Shredding like this.
  7. Aug 27, 2023 at 6:01 PM
    Tacoman10101
    Best way to find out is leave your truck in neutral with e brake off, get a friend or two to jump in the back and just lay under the truck and follow the music. Took me about 15 seconds.... Wasted so much time checking everything multiple times, I don't know why I didn't do it sooner
  8. Aug 28, 2023 at 7:28 AM
    YF_Ryan
    Kent, WA
    It's always the last thing you check :thumbsup:
    The Art Of Shredding likes this.
  9. Oct 27, 2023 at 2:51 PM
    2017 TRD Off Road
    So it’s my rear leafs. I think it’s called the military wrap? I had to pry it just a bit from the side of the rear passenger leaf spring. No more clunk. Took me a while to figure it out by just spraying everything with lubricant. Now I think I have a wheel bearing roaring. Could be jest my tires as I noticed it after rotating my tires. No change in noise when swerving. Jacked it up and have no slop and it sounds clean when spinning. Only seems to happen when going between 30-50 and has same tone through entire range. 4wd don’t change it and neutral don’t matter. I guess i will just keep searching.
  10. Oct 27, 2023 at 3:31 PM
    PasswordIsTaco123
    PasswordIsTaco123 Well-Known Member
    Scott
    Greenville SC
    2015 DCSB TRDOR
    2015 Silver Bullet Taco Installed: 5100's W OME887's +1/4leanspacer Toytec Boss Rear shocks Headstrong AAL + 1/2in block Ubolt Flip W superbumps Front Superbumps CB drop kit 4runner Trail Edition 17in Wheels Tires: Falken Wildpeak At3 C-load 275/70/17 Hooke Road Roof Rack Have but may/may not install Ex rear brake lines diff drop
    Check your Brake Pad clips, I had the same thing but on passenger side, big thunk when i'd hit large mounds or speed bumps and i went through the same stuff you did trying to diagnose and then found some people doing this double clip thing where its just a second of those little paper clip looking clips that they say you only need 1 on the bottom, as soon as I added the second clip to the top my thunk went away. just a possibility
  11. Oct 27, 2023 at 3:34 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    check u bolt torque and trailer hitch coupler for loose fit.
