Loud cracking sound when stepping into the bed?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Switchback, Feb 17, 2023.
  1. Feb 17, 2023 at 9:20 AM
    Switchback
    Switchback [OP] Well-Known Member
    22 Mag Grey SR 4wd SX
    Anyone else get a pretty loud noise when stepping into the bed? It’s right when I step in, so right past the folded down tailgate. It sounds like something is cracking, though I can’t see anything. Bed looks normal. And there’s no noise like this as I move around in the bed, it’s just that initial step in. I don’t remember that on my previous Tacoma, and wondering whether it’s something wrong? Thanks.
    HondaGM likes this.
  2. Feb 17, 2023 at 9:22 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    A loose bed bolt is allowing the bed to lift slightly, then sand is getting between the mount and the frame. Every time you step in the sand digs into the fiberglass of the bed making the sound.
    Really I dont know, but its a idea.
  3. Feb 17, 2023 at 9:30 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    How big a Boy are you?
  4. Feb 17, 2023 at 1:59 PM
    Switchback
    200lbs. But even if I were 750 I’d still not expect it to sound like it’s breaking when I get into it.
    TRP and HondaGM[QUOTED] like this.
  5. Feb 17, 2023 at 2:06 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I would say try getting down to 180 lbs, then try stepping into your bed again to see if it's still making the sound.
  6. Feb 17, 2023 at 2:12 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I’m a fat bastard at 275 and my bed doesn’t do that.
    TRP, HondaGM and Big tall dave like this.
  7. Feb 17, 2023 at 2:16 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Is it bad my mind read that in a fog horn leg horn voice?
  8. Feb 17, 2023 at 2:19 PM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    "I say, I say, how big a boy are you?!"
  9. Feb 17, 2023 at 2:24 PM
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    Same here, it’s probably just your knees.
    RIX TUX, TRP and HondaGM like this.
  10. Feb 17, 2023 at 2:27 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
  11. Feb 17, 2023 at 2:31 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ice, it's winter.
    LeakyAC likes this.
  12. Feb 17, 2023 at 2:34 PM
    TRP
    TRP Well-Known Member
    How much do you weigh!? :rofl:
  13. Feb 17, 2023 at 2:38 PM
    Switchback
    Thanks, think I’ll have them look at it at my next service.
    No ice here.
    It’s weird to me that it’s only in the one spot, like if I move around to the back of the bed it is fine. But that spot right at the front gives the noise each time. Thanks all.
  14. Feb 17, 2023 at 2:57 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Crawl under the bed and check it out (when temperature allows). You may have to lower the spare to get a good view. Have a helper step on the spot while you are underneath.
    Big tall dave, BC Hunter and TRP like this.
  15. Feb 17, 2023 at 3:17 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Change in in temp is enough
  16. Feb 17, 2023 at 6:16 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I think a good power wash under the bed. Then tighten the bolts on the bed
  17. Feb 17, 2023 at 10:47 PM
    Corrugated
    Corrugated 2023 TRD Sport Premium
    Surrey, British Columbia, Canada
    2023 Tacoma TRD Sport premium
    My 2023 long bed Sport does the same thing, in the same spot... I'll have to check underneath the bed and possibly tighten some hardware up...
  18. Feb 18, 2023 at 12:06 AM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    D ring bolts and dirt, stepping near it..
    sounds a lot like a splinter of cracked abs plastic rubbing against itself when flexed.
    the bolts have a cylindrical spacer to fill out the hole under the D ring and are about 3/4 in thick, stuff gets between there and its just like our leaf springs, squeak, crack, squeak, crack.
    But really, anywhere the bed touches metal, if there is grit, it can make noise
    Corrugated likes this.
  19. Feb 18, 2023 at 4:49 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    The sleeves are there to keep the bolts from crushing the bed when tightened, they bottom out on the frame work and the bolt washer. They should be pretty tight it's a hefty bolt.
  20. Feb 18, 2023 at 4:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    Matter if you enter from left or right side?
    Suspect one or both rear bed bolt needs a couple of ugga duggas.
