Loud creak when turning the wheel at a stop/low speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fivespeed, Apr 13, 2014.
  1. Apr 15, 2016 at 8:17 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I have a creaking coming from my front driver side corner. Sounds similar to that video.
    I looked at the rubber covering both the LBJ and the tie rod, they both seem intact. My truck is a 95, but it spent its whole life in CA until I brought it to MA last summer(its not very rusty). I just noticed this creaking last week.
    I saw people injecting grease under the rubber fittings. Has anyone tried that?
  2. Apr 17, 2016 at 12:45 PM
    jjsul
    James
    New Hampshire
    95.5 OME
    Well I checked under the drivers side wheel again and found a tear at the top of my lower ball joint. I sprayed some WD40 in there and the creaking stopped. Im planning to just replace the ball joints on both sides.
  3. Apr 26, 2016 at 6:25 PM
    rvdb
    rvdb Well-Known Member
    CA
    TRD Sport
    stuff that makes it better for my use...
    I am at a loss, I thought it was the Uca ball however it returned & sounds like it's from behind the skid plate however it comes & goes... I am going to borrow my daughters stethoscope & either Lose my hearing or figure this out.
  4. Jun 22, 2016 at 3:21 AM
    m.reed.1
    m.reed.1 Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
    sameeee issue, except mine is only when I turn my wheel left. Originally I cleaned from around the uniball, Thought I had fixed the issue.... but its back! I have a '15 w/ about 23,000k Icon stage 3 w/ tubular UCA
  5. Jul 8, 2016 at 5:04 PM
    rvdb
    CA
    TRD Sport
    Ok, the conclusion on my truck it was the UCA uniball is using the Boeshield T-9 Waterproof lube, this product has lasted far longer than the other products I tried and must penetrate better, knock on wood I have had no issue for two months since I used it, hope this helps.
    jackn7 and sjdv77 like this.
  6. Dec 21, 2016 at 12:02 PM
    IamMachines
    IamMachines Well-Known Member
    Kyle
    Flagstaff AZ
    2017 Black Tacoma 4x4 DCLB
    https://www.tacomaworld.com/threads/2017-tacoma-4x4-dc-lb-adventure-truck.449483/
    I have the same issue as you, AND I have the same setup, Icon Stage 3 with the Tubular UCA, however I have a 3rd gen.
    Have you figured out what it is? The mechanic that normally works on my truck is not available until next week and this issue is driving me crazy...
    Has anyone found it be the CV joint? I was looking to try and lube both sides, but cant figure out how gracefully get the rubber boot off without tearing it up.
  7. Dec 27, 2016 at 12:48 PM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    Not the CV, CV is a closed system and won't lose grease unless you blow the boot.. it's the UCA uniball. Just clean it out. Grime gets in there and wears them. ICON released new replacement Uniballs at SEMA, should fix the issue.
    Keep yo balls clean
    Some people use dry lube to keep them lubed without attracting dirt
  8. Dec 27, 2016 at 4:04 PM
    IamMachines
    Kyle
    Flagstaff AZ
    Yep I just took mine in for service. It was the uniball on the UCA.
    I have since got the Icon caps for the UCAs and the bags for my coil overs.
  9. Apr 14, 2017 at 7:54 PM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    My 3rd gen w/ Icons (uniball UCA) recently developed similar noises. I've got uniball caps and coilover covers on mine. Sprayed some dry lubricant into the UCAs and at the shock shafts yesterday, but after minimal driving, the noise persists. I wonder if the grease didn't get "worked in" yet, or whether it's something else... Truck's going in for service tomorrow, will have them take a look at this, too.
  10. May 8, 2017 at 6:24 PM
    evskie53
    evskie53 The Problem Child
    Denver
    2011 DCSB Sport
    I'm getting a similar noise but only when it is close to hitting the stop on the passenger side. Any ideas?
  11. May 8, 2017 at 6:30 PM
    rvdb
    CA
    TRD Sport
    For me having two Toyotas with Icon UCA I have been sticking with post #28 and its been working great. I put a bit on the clean ball joints and I'm done. And knock on wood its now been months and no noises. I tried other products and they did NOT hold up two days. Also and one with the caps, I had the caps and read a post on moisture getting trapped in there and sure enough the top of the bolt was showing the beginning signs of corrosion, pulled them off permanently. Good luck
  12. May 8, 2017 at 6:31 PM
    0210
    Vancouver, BC
    Noise went away after time and more lube on UCA ball joint.
  13. Nov 6, 2017 at 12:45 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    My truck started making squeaking noises after off roading and turned out to the uniballs on my UCAs that needed to be lubed. Squirted dry lube all over that bitch, now the sound is gone.
  14. Jul 14, 2019 at 9:58 AM
    Dirt Ferguson
    Dirt Ferguson Well-Known Member
    Daniel
    Napa Valley
    15 MGM DCSB TRD Sport
    KING 2.5 EXT, Total Chaos UCA, SCS F5, Katzkin
    Thread revival as I'm having the same problem. Going to try spraying my TC UCA uniballs first.
    What dry lubricant spray do folks recommend? I see some Dupont products as well as good'ol WD40 Dry spray available on Amazon.
  15. Feb 14, 2024 at 7:12 PM
    #35
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Thread revival again.... Did spraying dry lube on your uniballs work? Would CRC Dry PTFE Lube work? I'm only hearing it when I turn right, but that's enough to drive me nuts!
