Loud front end creak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by uyarbrough, Apr 30, 2023.
  1. Apr 30, 2023 at 9:05 PM
    uyarbrough
    uyarbrough [OP] Member
    Ulysses
    2017 Black Tacoma Limited
    I have a loud creak coming from my front end when I hit a large dip or bump, especially while turning. Can hear it coming from both sides separately and sometimes both at once. It’s inconsistent, it’ll sound terrible on one speed bump but dead silent on the next. Sounds like a dry bushing somewhere but I’ve been under the truck with penetrating lube soaking everything I can think of and nothing helps. Every mechanic I’ve visited acknowledges that it sounds bad but can’t pinpoint the source. Everything in the front end is tight and in good shape and the truck feels great on and off-road, except for this creak. Hoping someone else had this issue and figured it out, it’s driving me crazy! Here’s a clip of the noise: https://youtu.be/uzAwHaL3PMc
  2. Apr 30, 2023 at 10:08 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    A sound clip would help!
  3. Apr 30, 2023 at 11:20 PM
    MGMDesertTaco
    radiator support bushings?
    sbl23, Superdave1.0 and MalinoisDad like this.
  4. May 1, 2023 at 2:58 AM
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    Make sure your skid plate is fastened completely.
    Superdave1.0 and Junkhead like this.
  5. May 1, 2023 at 6:36 AM
    uyarbrough
    Ulysses
    Here’s a clip of the sound, couldn’t figure out how to upload last night
  6. May 1, 2023 at 6:38 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Sway Bar.
    Zuba Gooding Jr likes this.
  7. May 1, 2023 at 6:50 AM
    uyarbrough
    Ulysses
    That was my first thought but no improvement after spraying the bushings with penetrating lube, end links are also tight and well greased. Is there another greasable spot I’m not thinking of?
  8. May 1, 2023 at 6:51 AM
    uyarbrough
    Ulysses
    That was the culprit for a mystery rattle a couple years back but it’s all tight this time around
  9. May 1, 2023 at 6:54 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    2nd checking radiator support bushings.
    Superdave1.0 likes this.
  10. May 1, 2023 at 7:01 AM
    uyarbrough
    Ulysses
    Copy that, I’ll spray those and see if there’s any improvement
  11. May 1, 2023 at 7:05 AM
    uyarbrough
    Ulysses
    Also worth noting that the noise goes away after a long drive in wet weather And comes back when it dries out.
  12. May 1, 2023 at 7:15 AM
    MikeSpiller
    MikeSpiller Member
    From the sound of it, I'd say it's probably a bushing that's dried out and needs to be replaced. It's good that you've already checked everything and soaked it in penetrating lube. It's possible that you missed the culprit, though. Did you check the sway bar bushings and links? Those are common causes of creaking noises like that.
    It's interesting that the sound goes away after a long drive in wet weather. That could mean that there's a slight bit of moisture that's helping to lubricate the bushing and quiet the noise. That would support the theory that it's a dried-out bushing that needs to be replaced.
  13. May 1, 2023 at 7:20 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Did you have an alignment done recently?
    Check your LCA cam bolts.
  14. May 1, 2023 at 9:09 AM
    uyarbrough
    Ulysses
    LCA cam bolts are tight. Did have an alignment recently but the noise has been getting steadily worse through 2 separate alignments now.
    Taco-Grinder[QUOTED] likes this.
  15. May 1, 2023 at 9:14 AM
    uyarbrough
    Ulysses
    Definitely sounds like dry bushings, both sides started making the sound at exactly the same time though which seems unusual. Sway bar bushings and links are all good and lubricated. If, say, my LCA bushings were going bad wouldn’t I feel a clunk or something too? The creak is super loud in person but doesn’t effect the steering feel or ride quality
  16. May 1, 2023 at 9:16 AM
    uyarbrough
    Ulysses
    Radiator support bushings are tight and look undamaged, sprayed them and didn’t make a difference
  17. May 1, 2023 at 9:31 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you can move the sway bar side to side the bushings are worn out. There is a ring each side on the bar it's self that keeps it in place when the bushing ware it allows the ring to connect with the sway bar bracket.
  18. May 1, 2023 at 9:35 AM
    tcjacado
    tcjacado Well-Known Member
    I am going to bet its the rack and pinon or inner and outer tie rods. If not all three items.
  19. May 1, 2023 at 10:20 AM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    I recently swapped to new coilovers/shocks and the infamous “click” sound is gone when rolling over speed bumps, etc.
    It’s the bottom front shock bushing. And the cause “seems” to be the bolt. It doesn’t offer complete support with its shoulder. Check @tonered ’s build thread. Post#280 or something like that.
    In your case, the bushings are past their “tool-life.” It’s time to swap out the lower shock bushings, and stop spraying.
  20. May 1, 2023 at 10:46 AM
    uyarbrough
    Ulysses
    This sounds promising, the lower shock bushings are centered and don’t have play but I’ll remove the shocks and take a closer look
