Loud front end squeak that gets worse with speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan7, Oct 11, 2017.
  1. Oct 11, 2017 at 3:18 PM
    TacoMan7
    TacoMan7 [OP] Member
    Steven
    California
    2007 trd sport dbl 4x4
    King Extended Coilovers with TC UCA. ARB/OME Dakar 2.75 leaf springs with King 2.5 Remote Reservoirs
    My tacoma immediately makes a metal on metal noise along with a squeak when I start driving. It gets faster and louder as I drive faster . It does not get worse when I turn either way. The brakes feel fine no play. There is minor play in the cv axles. Please help! Ahaha
  2. Oct 11, 2017 at 4:03 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Little curious why it is funny... but anyways wheel bearings, driveshaft u joints, rock in your brakes or completely worn brakes, cvs, center carrier bearing, are all possible... I would start with greasing u joints and checking your wheel bearings.
  3. Oct 11, 2017 at 6:05 PM
    TacoMan7
    Steven
    California
    Already greased the u joints, brakes are brand new and the rotors are still fine. There is a little play In the wheels when I jacked it up and tried moving it. I will look into the other two things thank you very much!
    excorcist[QUOTED] likes this.
  4. Oct 11, 2017 at 6:48 PM
    excorcist
    Reno, NV
    No problem, there should be no play in the wheels at all when jacked up , and if the sound is that bad you should be able to here it by jacking up the truck and spinning the wheels with your hands and listen.
    One of these can be very valuable in situations like this and for 4$ its a no brainer to have in the garage:
  5. Oct 11, 2017 at 7:35 PM
    TacoMan7
    Steven
    California
    So I jacked up the truck and there is no play in the wheels, also I spun them both directions and you could barely hear a minor noise. Im trying to attach the video of the noise but itt won’t let me.
  6. Oct 11, 2017 at 7:46 PM
    excorcist
    Reno, NV
    I would try putting it on jack stands in the rear and put in gear (obviously have to be careful doing this) and see if you can hear it then.
  7. Oct 11, 2017 at 7:47 PM
    TacoMan7
    Steven
    California
  8. Oct 11, 2017 at 7:48 PM
    TacoMan7
    Steven
    California
    Check that vid out
  9. Oct 11, 2017 at 7:53 PM
    Stewbuff
    Stewbuff Well-Known Member
    Andrew
    Centerville, UT
    '05 AC TRD OR Impulse Red
    Diff Breather Extension
    Could be a loose exhaust heat shield
    excorcist likes this.
  10. Oct 11, 2017 at 7:54 PM
    TacoMan7
    Steven
    California
    I double checked all the heat shields:(
  11. Oct 11, 2017 at 7:58 PM
    excorcist
    Reno, NV
    Did you check the disc shields?
  12. Oct 11, 2017 at 7:59 PM
    excorcist
    Reno, NV
    And is it definitely coming from front end?
  13. Oct 11, 2017 at 8:04 PM
    TacoMan7
    Steven
    California
    I did not, I just watched a video of that noise and it sounds exactly like it. Yes it does sound like it is coming from the front end .
  14. Oct 13, 2017 at 1:10 PM
    TacoMan7
    Steven
    California
    Turned out to be the driver side wheel hub . Replaced it and the sound is now gone !
  15. Oct 13, 2017 at 1:41 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Glad you solved your issue. Now I know what a bad wheel bearing sounds like :)
