Loud Noise - only when accelerating, 45 MPH and above.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2008Tacoma200k, Jan 3, 2020.
  1. Jan 3, 2020 at 9:55 AM
    2008Tacoma200k
    2008Tacoma200k [OP] Member
    Sounds a little like the Millennium Falcon (only way I know how to describe it)
    Only starts when I get above a certain speed, and lightly pushing on gas to accelerate. If I press harder to go faster it quiets down.
    Also happens when I'm releasing the gas. It is coming from the rear, underneath.
    Here is a link to a video. I'm alternating between pressing and releasing the gas pedal
    https://photos.google.com/share/AF1...?key=OElxeXFrZG1lSVpuME9GRHdyNHVYM001TDdfVU13
  2. Jan 3, 2020 at 10:01 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Kind of sounds like a train horn from far away, that's odd. I had a sort of similar noise but more chirpy...it was in sync with the engine RPM speed. Turned out to be the bearing in the AC idler pulley was bad and needed replaced, pretty easy/cheap job. This sounds different but that's one thing to check just to see. The bearing in mine was very loose, you could get under the engine and move the pulley back/forth with your fingers
  3. Jan 3, 2020 at 11:05 AM
    2008Tacoma200k
    Edited to add: It's coming from the rear underneath.
  4. Jan 3, 2020 at 11:22 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    sounds like a bearing whine. check carrier bearing if 4x4.
  5. Jan 3, 2020 at 11:44 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    That sounds like something I'd want to find before I keep driving the truck! How long has your TPMS light been on? Possible tire problem or alignment issue?
  6. Jan 3, 2020 at 12:15 PM
    2008Tacoma200k
    Its a 2 wheel drive.
    I agree, that sound is scaring the crap out of me.
    The TPMS light came on a week or so ago, checked air pressure, added air to the tire, it went off. Came back on this week. Taking it the tire store this weekend to get that checked.
    Dont think its related to the tire, sound is directly related to hitting the acceleration pedal.
  7. Jan 3, 2020 at 12:19 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Sound can be tricky. Maybe it's not coming from the rear. I'd start checking pullies then wheel bearings.
    Shelf Life likes this.
  8. Jan 3, 2020 at 12:35 PM
    Shelf Life
    Rob
    Central Oregon
    That's what I was thinking. Sound can be real hard to pinpoint sometimes.
  9. Jan 3, 2020 at 12:42 PM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    How many miles? Sounds like rear differential gear whine. Start by draining the oil and inspecting the contents for metal shavings. Replace with a heavy weight oil like 85W-140, see if that helps.
  10. Jan 3, 2020 at 12:42 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    You say rear.... First thing I'd look at are your U- joints, especially since the noise is prevalent under load.
  11. Jan 3, 2020 at 12:48 PM
    rpowell25
    rpowell25 Well-Known Member
    Robert
    Walnut Creek, Ca
    2019 Tacoma DCSB TRD Off Road 4wd
    The list is long but distinguished
    Drive line noise, especially upon de-acceleration is generally in the rear end. Check the rear diff fluid immediately. Disconnect the driveshaft and inspect the u-joints. With the shaft out, grab a hold of the pinion and check for excessive play. You may want inspect the third member for abnormal wear on the ring and pinion gears.
    JC15Taco likes this.
  12. Jan 3, 2020 at 6:07 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Sounds expensive like the differential is dry as a bone.
    wheeliest likes this.
  13. Jan 3, 2020 at 8:06 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Does it always happen at the same RPM?
  14. Jan 4, 2020 at 1:16 PM
    2008Tacoma200k
    Unfortunately, this is the issue. Appreciate everyone's assistance and responses.
  15. Jan 4, 2020 at 1:19 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You opened the drain plug and little if anything came out?
  16. Jan 4, 2020 at 1:50 PM
    2008Tacoma200k
    I took it to a shop, but yes it was empty. Also, could see where it was leaking out.
  17. Jan 4, 2020 at 2:19 PM
    TrailYeti
    TrailYeti Well-Known Member
    Portland, Oregon
    05 TRD OR on SCS F5’s & 315/75r16’s
    Ouch.
    JC15Taco and Shelf Life like this.
  18. Jan 4, 2020 at 2:35 PM
    JC15Taco
    Jeff
    SK, Canada
    '15 TRD DCLB
    Didn't notice the leak?
    Glad you got it solved.
  19. Jan 4, 2020 at 3:30 PM
    eon_blue
    Azusa, CA
    At least you caught it before the diff seized up on you on the highway or something, that could have been bad
  20. Jan 6, 2020 at 5:42 PM
    2008Tacoma200k
    Ugh.. Overhaul vs Replacing the Axle assembly? $$$
