Loud Noise - only when accelerating, 45 MPH and above.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2008Tacoma200k, Jan 3, 2020.
  1. Jan 6, 2020 at 9:21 PM
    rpowell25
    rpowell25 Well-Known Member
    Robert
    Walnut Creek, Ca
    2019 Tacoma DCSB TRD Off Road 4wd
    The list is long but distinguished
    Used entire rear differential? Just swap the whole assembly. You mentioned you're 2wd...I'm betting a whole used rear end isn't that expensive and would be a pretty easy swap.
  2. Jan 7, 2020 at 5:06 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
  3. Jan 7, 2020 at 5:29 AM
    J $
    J $ Active Member
    Jared
    04 Silver Taco 4x4, 3.4L V6, TRD Extracab
    So sorry for your loss. You'll find members here are supportive and respectful in your time of distress.
  4. Jan 7, 2020 at 7:24 AM
    2008Tacoma200k
    2008Tacoma200k [OP] Member
    Appreciate all the feedback. When you say the whole assembly, the entire axle assembly? That's what the mechanic is suggesting.
  5. Jan 7, 2020 at 7:41 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Fortunately the scrap yards are full of them they used the same 3rd member for a long time. No doubt the final drive is toast but I comes out from the front worst issue is getting the axles out there is no real need to replace the entire thing.
  6. Jan 7, 2020 at 8:07 AM
    rpowell25
    Robert
    Walnut Creek, Ca
    Yes. If you can find a good used rear end for a few hundred bucks just swap the whole thing. Swapping the just the third member is not difficult but time consuming. I've purchased full assemblies and done rear end swaps without unbolting the leaf springs from the frame in under 2 hours. I've not done a Tacoma so your mileage may vary.
  7. Jan 8, 2020 at 6:00 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    No one said this will be an easy job. No matter what you are going to have to deal with rusty parts the jackpot is reasonably light and a one man job replacing the entire assembly is not and is cumbersome, heavy and probably will require new U bolts, bleeding the brakes etc. Being a 3rd member all you basically have to do is remove both axles, slide them out a few inches unbolt the jackpot bolt in a new one. The worst part of the job is removing the brake drums. A used diff assembly will also have questionable brakes so you will end up removing the brake drums any way.
