Loud popping/grinding noise!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kcrob1, Jan 28, 2011.
  1. Jan 28, 2011 at 9:34 PM
    kcrob1
    kcrob1 [OP] Choot It!
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Adjustable Billies, Debadged, Painted emblem on grille Kenwood Double din, polk components, co-ax, polk 8" sub & polk amp, TSB springs, 6000K hids, FJ Wheels
    My 2011 went in for the 10,000 mile service today. I drove it about 45 miles then I turned in a parking lot and heard this horrible pop in the rear of the truck. Thought maybe something was rolling around in the bed. Got out to see and there was nothing in my bed. Did it again 20 minutes later and this time it was definately somewhere in the back axle... It sounded like a hub breaking only on the back. They rotated the tires but the lugs are tight. Any ideas on what to look at before I take it to the dealer and cannot recreate the problem?
  2. Jan 28, 2011 at 9:37 PM
    kcrob1
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Yeah I'll be knocking on the door at 7am. Just curious of what it could be. Are ring and pinions bad about going out? Or axles breaking? Its all stock other than adj. billies
  3. Jan 28, 2011 at 9:47 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Usually when your rear goes (gears) out it a big loud BANG! And then you can go any where because the rear end it locked up.
    X2 for what Ryan said.
  4. Jan 29, 2011 at 11:58 AM
    kcrob1
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Well sat at the dealer for 2 hrs so they could tell me my reciever hitch moved and made the noise. I have had that in there since the day I bought my truck and it has never made that noise nor is it capable of being that loud. So I told him well I will take the hitch out and when my wheel or rear end come off the truck he was going to be dealing with a very pissed off customer. He made a note in the system so if something does happen it is documented. :rolleyes:
  5. Jan 29, 2011 at 12:52 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    I don't know about you but my hitch would clunk sometimes over a bump but never a grinding sound.
  6. Jan 29, 2011 at 12:57 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Stab in the dark , but did they rotate in your spare? If so could the spare carrier be loose and clunking back and forth?
  7. Jan 29, 2011 at 12:59 PM
    DriverSound
    SoCal
    Too few to list.
    The spare is a steel wheel. Shouldn't be rotated with the alloys.
  8. Jan 29, 2011 at 1:00 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    What all did they touch for the 10,000 mile service? Are you sure it's not in 4hi?
  9. Jan 29, 2011 at 1:18 PM
    OZ-T
    Peter North
    British Columbia
    True , on my old truck I had this issue of a clunking noise from the rear end and it wound up being a loose spare in the carrier .
    I opened my yap before thinking it through , but you're right , different wheels.
  10. Jan 29, 2011 at 7:28 PM
    kcrob1
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Well I have never heard it before and didnt turn hard or anything to make it slam as loud as it was...
    That was the first thing I checked, and its tight
    As far as I know all the normal front diff, rear diff, tranny plugs. Oil plug and filter and rotated the tires. Its not in 4wd. I figured a tire was probably loose but they said they were good. Haven't heard it today though. It sounded like a hub binding up and then snapping in half. Scared the shit out of me
  11. Jan 29, 2011 at 7:38 PM
    OffroadToy
    4X4 Offroad
    Since you have the Sport I wonder if maybe they forgot to add the friction additive to the rear diff?
  12. Mar 14, 2011 at 10:23 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Any update? I have an issue that might be related
  13. Mar 15, 2011 at 9:32 PM
    kcrob1
    Casey
    Montgomery, TX
    TRD SPORT CC/LB
    Haven't heard it again. Now it just won't start sometimes???
  14. Mar 15, 2011 at 9:37 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    That's weird
