Loud power steering plus milky fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by Truckrider, Mar 22, 2020.
  1. Mar 25, 2020 at 4:26 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Yes. Use a turkey baster or something to suck as much fluid out of the reservoir as you can before taking it off. Any you don't get out will spill out the bottom when you lift it off.
  2. Mar 25, 2020 at 4:33 PM
    Tacoscar-the-grouch
    Tacoscar-the-grouch Well-Known Member
    Josh
    North Idaho
    2001 Reg. Cab Tacoma
    OME kit 4.56's 235/85/16
    Gyrkin is correct. Also I just realized that you have the 6 cyl. motor. Your pump is a bit different then mine, but there are lots of online resources to discover how to work on it.
    This video should help you out a lot:
    https://www.youtube.com/watch?v=5k61KXRK8bM
    cruisedon66 and Truckrider[OP] like this.
  3. Apr 3, 2020 at 12:17 PM
    Truckrider
    Truckrider [OP] Your truck is your armor in this world.
    Tony
    Los Angeles CA
    2000 PreRunner 3.4L 2WD
    UPDATE: Pulled the reservoir. The screen was completely clogged and blocked by thick gunk. Gave it a bath in gasoline for a half hour. Totally made the screen clean. Put on a new o-ring and re-fitted the reservoir onto the pump. Had to gently tap it with a wood block and hammer to seat it all the way. Tightened it all up, filled with fluid and flushed it out a couple times. Works like new again, no whine. Thanks!!
    Timmah!, HiFire and Gyrkin like this.
  4. Apr 3, 2020 at 2:04 PM
    Tacoscar-the-grouch
    Josh
    North Idaho
    Hell yes, brother! Always nice when a project comes together with a little elbow grease as opposed to new parts.
    Truckrider[OP] likes this.
  5. Apr 3, 2020 at 2:27 PM
    Truckrider
    Tony
    Los Angeles CA
    Thanks all! Long live the Tacos in this changing world. Our trucks are our bunkers.
