loud rattle from under 2013,
Discussion in '2nd Gen. Tacomas (2005-2015)' started by white trd 6speed, Apr 28, 2013.
  1. Apr 29, 2013 at 9:19 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Unfortunately for you, I think those guys are smokin crack. Mine is an 11 but is the same model. It doesn't rattle while sitting in neutral.
    As stated earlier I have some loose plastic over the wheel well, but that's only when on bumpy roads.
  2. Apr 29, 2013 at 9:26 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    That just doesn't seem right? Idk? a new vehicle shouldn't have a rattle or a problem like that. iT'S NEW!!
    Brett
  3. Apr 29, 2013 at 9:39 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    If it's not moving, the driveshaft is not turning... there's nothing to cause the "play" to rattle.
    Find another dealer. These jackasses are blowing you off.
  4. Apr 29, 2013 at 10:42 PM
    white trd 6speed
    white trd 6speed [OP] Member
    jose
    CONUS
    white TRD off road 6 speed
    none yet
    just to clarify it rattles when i hit a bump or when on a rough road when I'm driving, so the drive shaft is turning, its not when it just sits there.
  5. Apr 30, 2013 at 5:56 AM
    rickc5
    rickc5 Well-Known Member
    Rick
    Whitewater, CO
    2021 Tacoma TRD Pro
    none
    That's the kiss of death from that dealer. Of course, it's total BS, but you are going to need to take it to another dealer and try again. Don't mention this first fiasco though.
    It doesn't matter what the root cause of the rattle is--a new truck should NOT rattle. I'm getting irritated just thinking about this.... Grrrrr.
  6. Apr 30, 2013 at 6:02 AM
    gradall
    gradall Member
    baltimore
    2013 trd 6 speed
    bestop
    do you have a tsb number? my investigations have led me to around this area of the truck and I'm rationalizing this as when the truck is under load all the slack is out of the bearing but when its in nuetral or clutch in the load is off the front off allowing a rattle over bumps. this is driving me nuts and I want some ammo to take to the dealership. I'm getting tired of hearing " we drove another truck on the lot and it does it so it must be normal " / rant off
  7. Apr 30, 2013 at 6:09 AM
    rustbus
    rustbus Well-Known Member
    western Canada
    2012 TrailTeam Pro - white
    Yea search Steering shaft rattle t-sb-0057-12. Sorry i though it was 13, but it says 12. Not that i know precisely what that number means.
    Let us know how it goes
  8. Apr 30, 2013 at 6:45 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
  9. Apr 30, 2013 at 7:24 AM
    gradall
    gradall Member
    baltimore
    2013 trd 6 speed
    bestop
    I'm sorry I imagined
    the carrier bearing its definately not the steering shaft the noise is coming from around the transmission area or slightly behind.
    Vassily28 that is for the 5 speed not the 6
  10. May 1, 2013 at 6:34 PM
    gradall
    gradall Member
    baltimore
    2013 trd 6 speed
    bestop
    just an update on my issue,
    i put the truck in 4 wheel and while cruising down the road the noise went away. When i got home i went under the truck and rotated the front driveshaft by hand and noise seems to be coming from the lower gear in the transfer case. Anybody? anything? its going back to the dealership for sure.
  11. May 1, 2013 at 6:42 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Sounds like you have the bad bearing issue like a lot of people have. Check it out search front diff vib. I had mine replaced under warranty. A shity design by Toyota for sure.
    Thanks,
    Brett
  12. May 1, 2013 at 8:37 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Ok so lets try to eliminate a couple of things. Are you lifted? Prob not but it doesn't matter and has happend to stock trucks also. If you can crawl under the truck and grab the cv shaft on the drivers side where it goes into the diff, see if you can wiggle it around a little. Check for excessive play ( in and out, side to side etc) now after that grab the passenger side and try to do the same. ( the cvs should be fairly tight into the diff ) if the driver Side has more play or slop in it it's a bad bearing on the inside of the diff. My truck had the same problem, both bearing and driver cv shaft was replaced under warranty.
    Let me know what you find? If its got slop in it that's the problem. Focus on this and not the transfer case. I bet that's the issue you have.
    Thanks,
    Brett
  13. May 2, 2013 at 9:09 AM
    gradall
    gradall Member
    baltimore
    2013 trd 6 speed
    bestop
    Thanks when I get home from work I'm going under. No lift on the truck. Thank you so mich again!
  14. May 2, 2013 at 9:24 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If you have a trailer hitch check the reciever. Mine fit loose and made a clunk noise when going over bumps.
  15. Jul 21, 2013 at 12:12 PM
    #35
    texastonka
    texastonka Member
    Justin
    Austin, Tx
    New. Stock. 2013.
    I have a 2wd 2013 TRD and rattles as well. Sounds like the wheel of fortune wheel.. Drives me crazy! It's a new truck. I need to take it in
  16. Jul 22, 2013 at 3:17 PM
    #36
    gradall
    gradall Member
    baltimore
    2013 trd 6 speed
    bestop
    I waited til the 10 k service to have them look at it, of course it wouldn't do it for them. good thing I have a new super tenere that doesn't rattle to ride.
  17. Jul 23, 2013 at 6:19 AM
    #37
    texastonka
    texastonka Member
    Justin
    Austin, Tx
    New. Stock. 2013.
    I took my truck in yesterday and drove a service guy.. It made the noise at 30mph 1,500rpm. He said it sounds like "Pre ignition" and asked me what type of gas I use. I left it with them to look at..
  18. Jul 23, 2013 at 7:22 PM
    #38
    texastonka
    texastonka Member
    Justin
    Austin, Tx
    New. Stock. 2013.
    i dropped my 2013 trd 2wd tacoma off yesterday for rattle noise. i had service tech ride with me to hear it. it makes the wheel of fortune noise at 1,300rpms at 30mph. he said it sounds like "pre ignition" and maybe i need to change my gas octane..
    today service tech called and said they "contacted Toyota" and it is being review since no cause or way to fix.. other tacomas have same problem.
    not happy.
  19. Jul 23, 2013 at 9:06 PM
    #39
    Rich91710
    Rich
    Los Angeles
    08 Base
    It's not the octane. Don't accept that for an answer.
    If they push the issue, show them in your owner's manual under "recommended fuel"
    The 2.7 requires regular.
    The 4.0 can benefit from premium, but it does not require more than regular.
    If you are getting preignition, the knock sensor is not working... it will cause the ECU to retard the timing to prevent knock, which can permanently damage the engine.
    If you are just cruising at 1300@30 and it's knocking, something is seriously wrong.
    It would only knock under acceleration.
  20. Jul 24, 2013 at 6:38 AM
    #40
    texastonka
    texastonka Member
    Justin
    Austin, Tx
    New. Stock. 2013.
    I am not going to accept it.. I think it's a serious issue. I have to work it up the chains now I guess.
    It does only knock under acceleration
