loud rattle from under 2013,
Discussion in '2nd Gen. Tacomas (2005-2015)' started by white trd 6speed, Apr 28, 2013.
  1. Jul 24, 2013 at 11:07 AM
    #41
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    Had a rock get stuck between my optional skid plate and the original skid plate. Made a metally rattle sound when i turn or start to take off. pried it out and it went away.
  2. Jul 24, 2013 at 11:40 AM
    #42
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    Mine does the same, and has since I drove it off the lot new a year and 17.5k miles ago, same conditions as well, definitely something in the trans (know not much about inner workings of a trans so I am not going to speculate) good to see this happens to other people as well
  3. Aug 25, 2013 at 8:01 AM
    #43
    texastonka
    texastonka Member
    Justin
    Austin, Tx
    New. Stock. 2013.
    so i contacted Toyota and they made a case and asked me to bring truck in again.. i did and drove another tech around to show him the noise. he said he was going to run tests and send info to Toyota engineers. heard back the next week from corp and they said they cannot find out what it is and nothing to fix. they asked me if it was ok. i said NO. i can't file lemon law since it is not an issue where they have done "work" on it.. there is nothing they have tried to fix since they dont know what it is. i just want them to buy the truck back or let me trade it for a new one and move on.. this stinks.
  4. Aug 25, 2013 at 8:30 AM
    #44
    woodchip
    woodchip Well-Known Member
    calgary,ab
    2013 taco 4x4 v6 manual
    firestone ride-rites
    my '13 is a noisy beast.I can't hear anything over the stereo tho.if it goes I don't worry about it.i don't care how noisy any of my equipment is,as long as it gets the job done.
  5. Aug 26, 2013 at 5:33 AM
    #45
    gradall
    gradall Member
    baltimore
    2013 trd 6 speed
    bestop
    I've pretty much given up hope on them finding my rattle. It does it just fine around my way but I go 30 miles to the dealership and it stops. I really miss the quality of my 2005 tacoma.
  6. Aug 28, 2013 at 5:55 AM
    #46
    texastonka
    texastonka Member
    Justin
    Austin, Tx
    New. Stock. 2013.
    i worry because i paid for a tacoma and don't want a rattle that nobody knows why or what it is. i can make mine make the noise with the dealer mech inside the truck every time.
  7. Dec 1, 2013 at 9:18 AM
    #47
    newtacomaowner13
    newtacomaowner13 Member
    emsmedic
    Durham , NC
    13 Tacoma Limited Long Bed
    Procomp 3" Lift Nfab Nerf Bars
    I have a 2013 Tacoma V6 4X4 that has about 2500 miles. I've had a problem with a dull rattle noise under the bed area. I just had the vehicle at the dealership for the third time for the same problem. They said they visually checked and tightened everything possible and it's still making the noise. I plan on taking the truck back again next week for the same problem. This is my first Tacoma and I spent a bunch on the long bed Limited model. It's really pissing me off that I'm having this problem and I'm starting to regret buying a Toyota. I thought they were reliable vehicles made to last?
  8. Dec 1, 2013 at 2:20 PM
    #48
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I have a similar noise in my '13 6sp. I found the yoke on the rear driveshaft to have a bit of slop in it. I'm pretty sure it's coming from there as it's louder when there isn't a load on it, ie clutch pressed in, etc... It was taken in once for the noise and I was also told it was "normal". Now that I'm pretty sure I identified the source, I'll press the dealer a bit harder next time it's in.
  9. Dec 2, 2013 at 3:04 PM
    #49
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    My 2010 developed a rattle I couldn't trace under the hood. Kind of like a loose metal fan shroud or something. It didn't get faster when accelerating. Turns out it was the catalytic converter falling apart in side. The cat was replace under warranty, the rattle stopped.
  10. Dec 2, 2013 at 3:39 PM
    #50
    82 yotaman
    82 yotaman H.O.G Hunter Of Gunman
    BUBBA
    Wyoming
    1982 toyta pickup/2013 toy MGM dcab 4x4 trd
    avs bugshield, avs inchannel vent visors, weather techs, trd shift knob, tailgate theft mod, windows tinted to 20%, wet okole front and back and black level 8 guardians wrapped in 265/75/R16 Duratracs oil catch can mod interior LED's, pop & lock pl5500, Leer 180 topper, OME full lift with Arb bullbar
    I have a 2013 6 speed dblcab and I had that noise in the rear end area drove me nuts than I thought maybe since it's new the spare tire is loose so I tightened the spare tire up there was a noticeable amount of slack went for a test drive and WOW no more rattle over bumps hopes this helps guys
  11. Jun 17, 2014 at 7:24 AM
    #51
    k19
    k19 fluffy the destroyer of worlds
    Canada
    2013 TRD sport DCSB
    2013 dbcb 6sp manual same rattle when going over bumps and while in gear and depress clutch or while in nutural.
    Had dealer replace my tranni and t-case noise is still there ...
    Dealer also hooked up microphones on different spots under the truck but didn't pin point location.
    I think it is a throwout bearing, but it is not covered by warranty.
    So for now , everytime i put truck on service i mention that it rattles, which forces dealer to look or disregard but it is documented.
  12. Aug 16, 2014 at 5:31 PM
    #52
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    I have it too. Dealer says it's the transmission, "they think". This dealer does not have any 6spds on the lot so they want to change the tranny and see how it goes. I've read a lot about this and though it does seem to be "normal", I have 2 friends with same truck ('08 & '13) that do NOT make the sound. So, hard to believe it's normal.
  13. Aug 16, 2014 at 6:13 PM
    #53
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I had this too - spare tire rattle / squeak. Drove me nuts. Tighten it up and see if that's it.
  14. Aug 19, 2014 at 5:07 AM
    #54
    k19
    Canada
    2013 TRD sport DCSB
    Keep us updated
